Originally Posted by horhey1622
I am new on here and just bought the lg65lm6200 and received it this past Friday and everthing is working great but the tv shows that it has to be updated to 04.02.85 system. I am currently running 03.02.85. Everytime I start the download it stops at around 16% sometimes less than that. My wifi is working correctly as I have other devices working on it. I called LG and they told me not to worry about the update. That made no sense to me. Is this update important and what does anyone suggest I do to try and fix this?
You can go here
LG 65LM6200 Support and manually download it to a USB thumb drive and update it that way. Just click on the link that says Software Update and you should find it and a PDF with instructions how to install it just below.[/quote]
Thank you very much Heavytoka I will try this.
