AVS › AVS Forum › 3D Central › 3D Displays › LG PASSIVE LM6200 dedicated thread...
LG PASSIVE LM6200 dedicated thread... - Page 33
post #961 of 998
Unless you set your Blu-Ray player to output at 24hz, the TV is always going to display 60hz. You can use the TV's ARC mode to pass the 5.1 surround to your receiver, if that's in fact what you are asking.
post #962 of 998
Originally Posted by hussain View Post
Hi,
I am unable to swtich audio tracks and turn subtitles off in media link and plex. I have the latest firmware.
Can anyone pleasse help me.
i use plex and have the same issue i think you can fix the issue by getting the "plex pass " release (not that i have tried it )
"Multi-user mode. All the users you share media with (inside and outside the house) get their own view of it (e.g. On Deck, view history) , and can select custom audio/subtitles. This feature is PlexPass only."
http://elan.plexapp.com/
post #963 of 998
Originally Posted by geoemm View Post
I used an AVSHD 709 calibration disk to calibrate my 47LM6200..i tried to make the colors,contrast and brightness as good as possible..i know that Heavytoka has posted an excellent spec ,but the whites are kind of too warm for me..If some one feel like me try my specs and let me know how you liked it..
Picture Menu:
Energy Saving: Off
Picture Mode: Expert 1
Backlight: 50 (reduce it more if you are watching in a dark environment)
Contrast: 92
Brightness: 51
H Sharpness: 0
V Sharpness: 0
Color: 47
Tint: 0
Aspect Ratio: Just Scan
Expert Control Menu:
Dynamic contrast: Off
Super Resolution: Off
Color Gamut: BT709
Edge Enhancer: Off
Color Filter: Off
Expert Pattern: Off [Grayed Out]
Gamma: 2.2
White Balance Menu:
Color Temperature: Warm
Method: 2-points
Pattern: Outer
Points: [High]
Red: -15
Green: 40
Blue: 50
Color Management System Menu:(Saturation, Tint , Luminance)
Red: (3,24,0)
Green: (2,0,1)
Blue: (2,0,3)
Cyan: (1,0,1)
Magenta:(2,0,2)
Yellow: (0,0,0)
Picture Option Menu
Noise reduction: Off(Auto for the antenna-as my cable is bad)
MPEG Noise Reduction: Off
Black level: Low
Eye Care: Off [Grayed Out]
TruMotion: Off(user-4 for cable,coz it kinds of make my bad cable look better, don't know why)
Real Cinema: On
These are really good! do u have settings for 3D? and for PS3?
post #964 of 998
Quick question on my 65". The box says it's 120hz but when I click on my screen it says 60hz. Is there a setting I need to change?
post #965 of 998
The INFO screen merely gives you signal data for the input being displayed (for example, 1920x1080@60Hz). The specs on the box refer to the capability of the TVs video processor...specifically, that it uses advanced algorithms to display a 120Hz image onscreen.
post #966 of 998
Can someone please tell me what is the default value for the backlight in Standard mode? I think I may have change it on the service menu... is it 75?
post #967 of 998
Mine is actually at 100 and since I don't use "standard" for anything I don't think I've changed it. Not guaranteeing it, but I certainly don't remember ever using standard so would not have been a reason to change it?
Good luck . . .
post #968 of 998
Downloaded the update 6.00.01...any new stuff?
post #969 of 998
Good luck . . .
in tool option 6 it says STD backlight 75, mine is a 47LM6200
post #970 of 998
there is a new privacy setting allowing user to turn off data collection.
also something called "live plus" on/off setting. dont know what this is
post #971 of 998
Hi to all,
I have a question regarding, the HDMI 1 port marked as ARC.
I have a PS4 connected to the TV through the HDMI 4 port!
The Ps4 is compatible with the SimpLink of LG but, when I connect the PS4 to the HDMI 1 port, the TV doesn't detect any signal! But when using the other ports it works flawsly!
I also enable the SimpLink from the other port (4) and it works great with the PS4.
The question is, what does it takes to make the PS4 work with the first HDMI port?
Is it required a special audio only device?
post #972 of 998
ARC is intended to work with a ARC-capable AV receiver. The PS4 should also be connected to an AVR so it can decode DTS HD Master Audio, Dolby TrueHD, and Dolby Digital Plus audio tracks from Blu-Ray discs.
post #973 of 998
Hi, I got in the service menu of the 47LM6200 and I'm not sure if I changed the Backlight in Tool 6 where it says STD, can you please tell me is the default factory value for the Backlight in Standard picture mode? is it 75? Thanks..
post #974 of 998
It is 75.
Quick question: Does selecting Expert 1 (or 2) from the Picture Mode setting get rid of the "Game" picture mode faster processing time? I remember when setting my TV up, unless I set it up as "Game" I'd get input lag.
Edited by Coxis - 12/13/13 at 7:59pm
post #975 of 998
Originally Posted by Coxis View Post
It is 75.
Thanks and try to rename it to PC
post #976 of 998
I tried the settings in this thread but I found that intelligent sensor does a pretty good job to the colors when connected with my laptop.
I have my laptop connected to my LG via HDMI with the device name "Notebook". It makes the text much sharper. Otherwise my notebook's text look fuzzy and the picture look dull.
With my PS4, I just use game mode. It also does a pretty good job with the colors. With game mode, most of the pictures settings are not available.
I have a Roku 3 which I have yet to adjust. I will change the picture settings for that device soon.
Anyone have any recommendations to the sound settings? I have my 42LM6200 on the stand next to a wall. I currently find cinema to be the best.
post #977 of 998
I only have this problem, every time i use youtube app, the tv freeze and i have to power off to fix it any solution ?
post #978 of 998
It's a bug introduced with one of the recent firmware updates, and LG has been made aware of it. No telling what (if anything) they'll do about it.
post #979 of 998
My 65LM6200 has been randomly shutting off, then comes right back on a few seconds later, almost like it's rebooting or something.
Has anyone ever had this happen? Right now it's doing it 2-3 times per day.
post #980 of 998
Yeah I've had that happen with my 55". It was a while ago now, but iirc a firmware update fixed it.
post #981 of 998
Just curious . . . how are any of you watching youtube direct? When I try it says I need flash player.
Or are you watching youtubes "from your laptop or other device" ported to the big screen?
post #982 of 998
You may need to update the TV's firmware. Be warned, however, that the current implementation of YT via LG Smart Apps is very poor...it crashes often requiring you to power-cycle the TV. I have a couple of components connected to the TV which handle YT well, including a Roku 3.
post #983 of 998
I downloaded the most recent update yesterday and had no issues, but today it has done it three times.
Suppose I better call someone or take it back? I assume it has a one year warranty?
post #984 of 998
It does have a one year warranty. You should contact LG to see what they suggest, though...that model has been discontinued.
post #985 of 998
Hi
I have the LG 55LM6200 and i wanted to know if anybody knows if the standard remote for the 65lm6200 part# AKB3615313 Will work with it. I just cant stand the magic remote anymore.
post #986 of 998
Originally Posted by gabrielbanc View Post
Hi
Yes, the standard remote works just fine.
post #987 of 998
Hi
Thanks for your help Rudy1 :D. That makes me happy!!!!!
post #988 of 998
Audio sync in recordings slowly gets further and further out.
We just got this set a couple of weeks back and so this past week I decided to buy a small HD to use with the TV record feature on the set. I tested it with a programme I was watching and it was all good, playback was fine,I could fast forward and rewind all ok, and audio and image were in sync. Likewise pausing live TV all worked fine.
I then set up the scheduled dvr function to record a could of things during the week when we were out. The sound in these recordings starts off in sync and then gets more and more out of sync as the recording goes on. I just upgraded to the latest revision of the TV bios but still no change.
Anyone else have this problem or know how to fix it?
Cheers!
post #989 of 998
Hmmh, I have recorded movies over 3 hours in length and, for example, the Eric Clapton Crossroads programs on Palladia that were 5 hours and did not experience audio lag.
Have not seen this.
post #990 of 998
Having Problems with WiFi on my 55"LM6200. It's been working great for about 10 months now every time I turn off the set it loses connectivity when I turn it back on. I have to select my wireless network from the list and re-enter my security code. I usually have to do this twice before it connects but sometimes it takes more tries. The network always shows up in the list as having the strongest possible signal strength. I don't remember having this problem before I updated to latest firmware (Version 06.01.03). We have laptops and smart phones attaching automatically to the network with no problems and use WEP for our security.
Any thoughts would be appreciated!
  Back to Forum: 3D Displays
