Bella Court Cinema
post #1 of 8
Well it's time to start the Bella Court Cinema and a new house. This is my first build, so I am going to need some guidance. We will break ground around the 16th of April. And yes I will be stealing I mean borrowing some ideals.
Seating:
1st Row: 4 Movie Theater seats 12' 6 or 13 from screen
2nd Row: 5 Movie Theater seats 14' 6 or 15' from screen
Speakers: Klipsch
Center: RC 62 II
Front floor standing: RF 82 II
Side Surround: RS 52 II
Back Ceiling: CDT-5650
SUB: Veladyne 2 Impact-12
Room Dimensions:
Width 16' Depth 23'
Ceiling: 10' with barrel arch in the middle (8'x15')
painted by Night Sky Murals
Equipment:
A/V Receiver: Marantz SR 7005 (7.2)
Blu-Ray: Oppo DBP-93
Projector: Epson 6010
Power Conditioner: Furman Elite 15 DMI
Screen: 142" Diagonal Carada Criterion Brilliant White
Remote: IPad with IRule and 2 GLOBAL CACHE GC-100-12
Lighting: Lurton Grafik Eye
Apple TV
Walls Sound Proofing:
QuietRock 5/8 EZ Snap
Open cell spray foam
Plans
Lot
post #2 of 8
Originally Posted by trenter33 View Post
Seating:
This must be an April fool joke or else you have very small seats! You need about 6'6" between rows if using reclining seats.
post #3 of 8
No it's not a joke, they are stadium theater seats. It may need to be 3', but they don't recline. Not a great picture, but these are the chairs.
post #4 of 8
You should read up on soundproofing.
thesoundproofingcompany.com
Quietrock alone won't get it done.
post #5 of 8
+1 regarding the sound proofing. Spray foam is not a good choice for sound isolation either. The spray foam people will probably tell you it's the best thing to ever happen to sound isolation, but from what I've read it doesn't perform well at lower frequencies.
Also, have you considered enlisting one of the acoustic design services? A barrel ceiling will probably introduce some "issues" that will need to be dealt with. My guess is it will tend to focus the sound into the center of the room.
post #6 of 8
Thanks guys looks like I have so research to do.
post #7 of 8
Don't overlook the need for a significant upgrade in the HVAC for this room,
Air tight soundproofed room, 9 people, small space heater (Projector), equipment and lights. Without an over-sized set up it will get ugly, even in the winter. If the duct work is connected to the rest of the house you need to take special measures to minimize sound traveling through the ducts. One solution is to use acoustically lined ducts.
post #8 of 8
HVAC taken care of. Thanks
