AVS › AVS Forum › Blu-ray & HD DVD › Official AVS Blu-ray Disc Reviews › Mission: Impossible - Ghost Protocol (Blu-ray) Official AVSForum Review
Mission: Impossible - Ghost Protocol (Blu-ray) Official AVSForum Review - Page 2
post #31 of 156
Him hanging on the building. Must be backdrop is blue.
post #32 of 156
Hated MI:3 and almost passed on going to see Ghost Protocol, but glad I didn't, because I enjoyed it quite a bit. Will be picking up the Blu Ray; surprised they went Dolby TrueHD with this one, since every other release seems to be DTS-MA these days.
post #33 of 156
Great movie with great action! WOW
post #34 of 156
Nope. He really did do that.
http://www.firstshowing.net/2011/wat...ol-featurette/
post #35 of 156
That's good stuff.
post #36 of 156
I wish they would release a imax shifting ar one
post #37 of 156
Paramount / DreamWorks appears to do well with TrueHD than DTS HD MA. Although both should sound identical, for some reason Paramount appears to using TrueHD on famous titles and giving it a special treatment. Maybe, it is due to bit rate limitation to accommodate multiple audio tracks on their overseas releases.
post #38 of 156
for some reason not satisfied with the story...
post #39 of 156
Wait how many more years?
post #40 of 156
Loved the film, but hated that last 5 mins when it becomes mi:3 again
post #41 of 156
Thanks for the review Ralph, although you are quite articulate when it comes to your audio/video commentary, and believe me, I really appreiate all your comments, I would like to see you elaborate on why the PQ, for example in this particular title, did not warrant a higher score.....
I watched this movie on Saturday and I did notice some "noise" in the picture......two scenes that come to mind are when they are in the jet talking about the magnet suit, look at the walls behind them. There seems to be some "blotching" or unevenness to the walls, it is also very noticeable in the team's Dubai hideout, where the walls again show some "odd" looking video anomaly....I do not know what the exact technical term might be for this.
Hidef Digest review by Michael S. Palmer, just confirmed what I saw on Saturday's viewing of this film.
http://bluray.highdefdigest.com/6566...ssible_gp.html
"In terms of flaws, while the only thing on the first disc is the film and its soundtracks, I did find one compression issue: banding. I noticed it in the scenes where we get to the team's Dubai hideout. Being smoky, darkly lit, and filled with about 800 variations on the color brown, I noticed a couple subtle, blocky bands in the background walls and stairs. Not the end of the world, really, and pretty hard to find, but there if you look closely."
Would love to hear more comments on why a title falls short of perfect, if perfect even exists.
Thanks again,
Big Fan
Paul
post #42 of 156
Paul,
Banding can be caused by many things and is most likely equipment/calibration related. Can you give me the exact time stamp and I'll check on tow different systems in my house (JVC front projector and a plasma). Both have been calibrated to D65 and I should be able to tell whether it's on the disc or not. A third test I can run is on my computer monitor, which is also calibrated to D65, but because of the LCD technology, it is much more prone to banding than either one of my other displays.
post #43 of 156
Hi Dave, good to talk to you again.
I would not call it "banding" by any means, as it was originally refered to by Michael S. Palmer over at Hidef Digest. It just seems more like "block noise", as sometimes seen in overly compressed Sat/Cable HD transmissions with images in the background.
Sorry I rented the movie, so I do not have a time stamp to give you, however, if you look at those two scenes as I described them in my post above (each scene is only about 2 minutes), the video anomaly is quite noticeable. Again, I am pickier than most, and I always trust what I see on my display.
For what it's worth, I have a 60" Pioneer Kuro, that has been professionally calibrated and I use my Oppo BDP93 as my source player.
Paul
post #44 of 156
Paul
Out of interest Paul. What combination of Color Space and Deep Color are you using in your Oppo? Are you going direct to the KURO for picture or via an AVR?
This is just to see if you are seeing the same thing i am.
post #45 of 156
Paul
Paul, I've made note of the scenes and will check on my displays tonight. From your setup, I doubt it's any of your equipment
post #46 of 156
Paul
Greetings,
Paul, I don't recall any extraneous noise and my notes don't relfect it either but I will go over those scenes again and report back.
post #47 of 156
Hi guys,
Starman7, the Oppo 93 is set to "RGB" colour space with "source direct" for resolution. Bob pariseau and I went through some great lenghts to try to get the best out of the Oppo based on his "Ratatouille" scene.....see the Oppo threads regarding this. As for my pre amp the Integra DHC 80.3 it is set to pass the HDMI signal "untouched".
Dave and Ralph, when looking at those scenes, keep your eyes in the backgrounds (walls, objects etc,) this is where the extraneous noise shows up.
Looking forward to your conclusions.
Paul
post #48 of 156
Hi guys,
Starman7, the Oppo 93 is set to "RGB" colour space with "source direct" for resolution. Bob pariseau and I went through some great lenghts to try to get the best out of the Oppo based on his "Ratatouille" scene.....see the Oppo threads regarding this. As for my pre amp the Integra DHC 80.3 it is set to pass the HDMI signal "untouched". Paul
Thanks Paul.
Yes, familiar with the "Ratatouile" test myself.
So you have it set to "RGB" (is that "RGB VIDEO LEVEL"?) and what about the DEEP COLOUR setting?
Thanks again.
Cheers, Starman7
post #49 of 156
^^ Yes, RGB video level, deep colour OFF. It is quite noticeable how smooth that ramp pattern in the Ratatouille scene is with these settings on MY SETUP. Some other Kuro owners have also confirmed these settings as the perferred choice.
Paul
post #50 of 156
Hi guys,
Paul
Greetings,
Paul, I just went through the sequence on the plane and the entire sequence in Dubai. I didn't observe any "noise" in the image/background walls. Over Simon Pegg's shoulder on the plane the wall is two toned but solid and noise free.
I don't know what to make of what you're seeing.
post #51 of 156
Paul
Yes, I agree. I too found RGB Video Level to be the best Color Space setting on my Oppo BDP-95 into my Pioneer KURO. However, even with the "Ratatouile" scene I could NOT detect any difference in the banding / ramp pattern no matter which Deep Color setting I chose. I left it on 36 bit.
REALLY want that Mission Impossible Best Buy Exclusive!
post #52 of 156
Originally Posted by Ralph Potts View Post
Greetings,
Hi Ralph, thanks again for the effort.....I really do not know what to say, except that I was not the only one who saw this.
The fact that Michael S. Palmer, at Hidef Digest confirmed what I saw on my Saturday's viewing of this film, is making me think that it might perhaps be just a few bad disks.???
I'll wait for some others to reply here.......btw, you tested this on your projector, did you not? I wonder if this is more apparent on a plasma or LCD.
Paul
post #53 of 156
Hi Paul, while I understand how reviewers have this already, I have to ask how you were able to rent this so early?
post #54 of 156
Paul
Greetings,
Paul, I did view it on my projector. Dave V. will be able to comment regarding what he sees on his plasma.
post #55 of 156
Thanks for your beautiful Review, that is simply awesome movie and the writer really did its well in writing it. But, actors and director--over all member of team did their best in this movie. It is heart touching movie i will see it again as soon i have leisure time again
post #56 of 156
A near by independant video rental store in Toronto , Canada hey!
Paul
post #57 of 156
Dreamworks seems to exclusively use TRUEHD. Paramount seems mostly DTS-MA, but they have TRUEHD on certain releases. Not sure the rhyme or reason?
Then again, with Dreamworks now being distributed via Disney (War Horse) seems they may be going DTSMA.
post #58 of 156
Im hoping to pick this up today or tomorrow.
post #59 of 156
Paul
I just watched my copy, and I don't see what it was that you saw.
If this condition persists I suggest that you see a doctor.
lol
post #60 of 156
Paul
Nice! I am in Cambridge, On. but will have to wait until tomorrow.
cheers,
