Originally Posted by
SAMIK
I'm sure you're not saying that the Infinity, as good a speaker as it is, is the equal of the Wattpuppy.
Right, the Infinity might be the better speaker.
There is really no standard for producing frequency response curves,
Which high end audio dealer told you that?
besides they usually only measure on-axis response.
Also, some speaker manufacturers add bits of color to their spekers to make them more listenable.
Which high end audio dealer told you that expensive speakers are somehow always immune to that sort of chicanery?
I do understand your point,and I agree with you. Money is not always a measure of quality.
I've been to high end audio shows and listened to a lot of very expensive speakers. Some of them have been pretty horrible. Some of them are pretty good, but represented horrible values, given what can be obtained for reasonable prices.
There are ways to build speakers with outstanding technical performance, and it is not cheap, but frankly I don't see a lot of high end manufacturers doing that. BTW the technical advantages of speakers built this way are readily measurable and they do provide improved sound quality. However, there is only so much that can be done with a few small drivers which is what you find in most high end speakers.
Take the Watt Puppy 8 - two 8 inch woofers, a 7 inch midrange and a dome tweeter. There are profound limits to the kind of bass extension and dynamic range that can be obtained by means of this technology.
For $11,200 a piece, I would expect a technical tour de force, not a reiteration of the same basic technology that can be obtained with quality hardware selling for 1/20th of the price.
However, it doesn't ring true to say that all speakers that cost more than, let's say $5000, are generally equal to those under $500.
Technology should not be analyzed with the price tags showing. The whole point of products like the Watt Puppies is making them financially credible to those who are technology naive. Not many people seem to take the bait. Wise persons, those who avoid drinking the high end audio kool Aid.
