AVS › AVS Forum › Display Devices › Display Calibration › Question about spyder4 colorometer
post #1 of 10
would the spyder4 express coupled with the AVS rec.709 DVD be fine to calibrate a TV or would i be completely stupid to even attempt this? would it be better to go with the spyder4 pro (which would be the absolute highest i can go in terms of price)?
i would *like* to be able to properly calibrate my TV. i've done some adjustments using the AVS rec.709 basic settings images (just brightness, contrast adjustments, nothing in the color management or 2/20 point IRE sections) but i don't have a lot of disposable income to be able to afford the higher end colorometers/software.
i mean, things certainly look *okay*, but i can definitely tell that the greyscale needs to be tweaked, and i know i can't accurately do it by eye.
any advice would be greatly appreciated.
thanks!
post #2 of 10
thanks!
You may want to hold off on your decision until next week when we have announced our new DIY calibration kit rental program.
post #3 of 10
does this program extend to canada?
post #4 of 10
You may also want to see what controls your tv has. If has the very basic controls, it may not be a worthwhile investment.
post #5 of 10
it's an LG 50PV400, so it does have some pretty "advanced" controls - standard brightness/contrast/colour/tint/sharpness controls as well as 2 or 20 point IRE, and colour management system. it also has colour standard settings (standard or wide) and white balance setting (cool, medium or warm).
so far, i just have the brightness/contrast/sharpness/colour/tint adjusted. i have not adjusted any of the IRE or CMS settings (they are all set to 0).
if there's a way to adjust the IRE settings by eye to get a neutral greyscale without the use of a meter, that'd be really great, but i know that's not exactly possible (or at the very least - difficult to achieve).
post #6 of 10
set the color temp to the warmest preset, that should get you closest to correct without the needed tools.
post #7 of 10
Yes it will
post #8 of 10
thanks to those that responded! much appreciated.
post #9 of 10
Here is the information about our calibration kit rental program:
http://store.spectracal.com/consumer/rent.html
post #10 of 10
hey thanks, i'll certainly keep this in mind should i decide to go with a more advanced calibration. i'm pretty happy with how it looks right now, but i would obviously *love* to have it perfect (or as close to perfect as possible).
