So after building my first sub and running some sweeps in REW I have noticed a huge null around the 20hz range. I do not have any measuring equipment but the null is pretty defined. Measuring equpiment is something I am working on as well as getting a MiniDSP. The sub sounds great but when I get around 20hz the whole room gets quite then picks up around 18hz and gets the room shaking at 14.5.
My build is a Dayton RSS390HF in a 4.3 ft^3 cube powered by a Crown XLS 1000 with an Onkyo RC260. I have run Audyssey. My question is is it possible I have a leak in the sub that would cause this or does it just need some good EQ action. I understand the effects of different room placement, and I have tried moving the sub around but I get the same effect no matter where it is. I see the sub moving but the room is almost dead silent. No vibrations... nothing, I hear the woofer moving but no bass. I used a ton of silicone to make sure everything was sealed and used the lighter trick to check for seals. However when checking around the mounting screws I cannot tell if there is a leak or it is just the woofer making the flame move.
Any thoughts?
Any thoughts?
hopefully I can wrap my head around it. I flipped through it real quick and looks like there is some good info. I will read it tomorrow - 3am here, time for sleep
