AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Kinect + Projector Experiences
post #1 of 4
Hello all,
I had a similar post awhile back in the Devices category. Thought there may be more responses here.
I am in the process of finishing my basement. I will have a projector for viewing purposes. I will be moving my gaming to this area. I would like to still have use of the Kinect. The projector will be mounted at close to 7' high. I am expecting my throw distance to be roughly 12'.
Can anyone chime in on their experience using kinect with a projector. My primary concern is casting a shadow on the screen when playing. Thoughts?
post #2 of 4
The only issue with my projector is the shadow.... If you can swing it have the projector mounted infront of your play space and this won't be an issue. I basically play right in front of mine and can get in the lightpath when I jump (quite a few things on kinect require you to jump).
post #3 of 4
I'm in the same boat with mine as well. I have the sensor below the bottom of the screen, about 3 feet off of the ground, but due to my space setup, I'm right under / in front of the projector when I play. Being 6' 2" tall with 7' ceilings makes it a little cramped.
post #4 of 4
It looks like I will be going with a LCD with ample lens shift. I would like to place the projector in the center for symmetry. However I wonder if I would be better off mounting the projector off to the left.
  Back to Forum: Xbox Area
