Originally Posted by Rock Flint
The way to handle abrupt transitions between clips is to put a fade or crossfade transition between them. I'm not familiar with Magix Movie Edit Pro but if it is anything like most of the other packages it will have a group of transitions that you can drag and drop on the place where the two clips meet. As far as which format to save your movies in, I normally use .mp4 at either 1280 x 720 or 1920 x 1080 since I post on Vimeo and Vimeo prefers .mp4 format. In any case, I try to save my movies in the highest quality the camera and software together can produce. Saving space by making reduced quality videos seems counterproductive. Why spend so much money on a good camcorder and then reduce the quality of the output to save storage space? Today you can buy additional hard drives with capacities up to 4tb. I just replace the older, smaller hard drives with newer, faster, bigger ones.
Good luck.
Good luck.
Thanks for the reply.. I think you might have misunderstood the question about the joining of two files.. Say for example you're filming a continuous scene that results in two 4gb mts file.. ideally, you just butt join the two scene as it's a continuous scene.. Some cameras I'd tested will have a blip in audio and video just at that point while others won't.. You can't put in a transition or fade in the middle of a speaking scene or fast action scene as it will be very noticeable. If I'm filming a scene where we would have to pause and reset angles, lighting or scenery, then this is not a problem at all, as you run the video a few seconds longer at the start and finish of that scene.. but it's the longer scenes that produce the multi files that I am concerned about.
Cheers
Wanting a new vid cam for our first grandchild coming in February. (Wow! am I really saying that?) The other day I found out about the new HC-V720 coming out in Feb also...
I says to me wife, "Honey I'm not finding another good deal on that camera, probably because a new model is coming out soon" and she says. "Well if a new model is coming out, why would you get the old one" and I says, "Well the new ones over $500", and then she says, "So what, I have over $600 saved for a new camera, just get it"
