AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Is this bonus room capable of supporting a ceiling mounted projector?
post #1 of 3
I really appreciate you guys reading this.
I'm wanting to put a pull down projection screen over the window and mount a projector on the ceiling. I'll have the exact measurements of the room in a few days but just based off what you can see, what will I need to do to make this happen? Is the room big enough for a 100" screen? How bout 120"? Will I need to move the ceiling fan back several feet for optimal projector placement?
If the room won't work for a projector, that's fine too. I had my heart set on a projector but if it can't be done, it can't be done.
post #2 of 3
Without exact dimensions it is hard to say for sure, but it certainly seems to be a good space for a projector. You will need to black out that window and most likely will lose the ceiling fan, but it seems very doable.
post #3 of 3
Ceiling fan will need to go (or be moved back) but that looks like a perfect room for a little theater. All depends how wide it is between the roof pitch.
