I bought a Runco DHD Vivix II with DVI IN/OUT and was going to use it to upconvert video signals from older sources to my Samsung 1080P flat panel. I know that the DHD only does 720P and I'm fine with that. The first concern with the DHD is that I keep seeing the front panel display show "check display" upon first powering up. I've read that I'm suppose to use either the S-Video or component input to 1st setup the DHD. I connected a S-Video source to the Svid 1 input. I've also selected the svid1 input, yet the DHD keeps showing "S Video 1 No Signal". I've connected the S-Video source to a less expensive upconverter and it will display on the flat panel using the inexpensive upconverter's HDMI output. The DHD has been connected to my flat panel with the following connections and always showed "check display" every time: DVI-D dual link to HDMI cable, DVI-D dual link to HDMI adaptor and HDMI cable, DVI-D single link to HDMI adaptor and HDMI cable. The flat panel never sees a signal from the DHD controller. Is this DHD controller unable to work with a Samsung HDMI flat panel even though both the DVI output and HDMI input are HDCP compliant?
Runco Vivix II problem
AVS Top Picks
post #2 of 22
4/4/12 at 6:02am
post #3 of 22
4/4/12 at 11:47am
post #5 of 22
4/4/12 at 3:08pm
post #8 of 22
4/4/12 at 7:48pm
post #9 of 22
4/8/12 at 7:52am
post #10 of 22
4/9/12 at 4:33am
post #11 of 22
4/9/12 at 10:07am
post #12 of 22
4/23/12 at 12:34am
post #13 of 22
4/23/12 at 12:39am
post #14 of 22
4/23/12 at 6:03am
post #15 of 22
4/23/12 at 10:10am
post #16 of 22
4/24/12 at 5:13am
post #17 of 22
5/9/12 at 8:45am
post #18 of 22
5/9/12 at 10:42am
post #19 of 22
5/9/12 at 5:20pm
post #20 of 22
5/11/12 at 3:40pm
post #21 of 22
5/11/12 at 4:47pm
post #22 of 22
5/12/12 at 4:33am
After six-eight hours of calibrating and tweaking, it made a RPTV look like a reference FPTV...well, almost
