Not familiar of either of those models, but if you're serious you should also consider the Sony BDP-S790 player as well.I upgraded to it from BDP-S770 last year and the difference between them is amazing. New dual-core processor is main reason for that.
Plasma dithering can start to take on a grainy / noisy look if the output is too high. Even if its calibrated to perfection, dithering will always be present. Another possibility is low level noise from your disk player or noise introduced by your cabling.
Try nighttime ones tonight
