Originally Posted by
pdhdtv
I purchased the Samsung 3D glasses SSG-4100GB and they work fine. They are cheaper, less than $19, but require using small batteries which are very cheap. I don't have a set of Panasonic glasses to compare. Maybe someone can comment if there is any difference in the 3D picture quality between the two.
They are identical to my eyes in terms of image quality, but the panny glasses envelope your eyes better. The Samsungs don't curve and unless you're in a super dark room will have reflections on the inside of the lenses as to what is lit behind you. Can be annoying but not a deal breaker. One thing I notice is that the Samsungs are not quite as dark, but that might be due to the more open design of the lenses.
dmaul1114
I tried the Panny's and Samsung glasses--couldn't tell any difference in quality.
I know have a passive Panny LED set (55" ET5). I actually prefer the 3D on it. Easier on my eyes, and I notice less blurring/double imaging on things far forward in the 3D space (pop out type effects etc.) than I did on the UT50 I tried for a couple of weeks. The resolution is lower though as things do sometimes look a tad more pixelated than on the plasma when watching 3D. Worthwhile trade off for me personally for the lesser eye strain and less blurring/double imaging (I guess that's what people mean when they talk about cross talk?).
Crosstalk = double imaging/ghosting yes I think that is correct. That is what I believe it is anyways. Using a BDP that allows for 24p and changing your TV to 48Hz lessens it considerably, but does not eliminate it altogether
pdhdtv
Any suggestions on 3D movies that pop-out of the screen. So far the 3D movies that I have seen have more of a deep "into the screen" effect and very few pop-out effects.
Go
here and take a gander. These guys do nothing but post on topics about what you're asking
Some of the best pop-out stuff I've ever seen can be seen on youtube. Like
this for example. It's also funny to watch the host
Be sure to choose the "side-by-side" method under "3D settings" (or maybe its "interleaved" iirc)
I just randomly did a search on youtube for "best 3d"
Edited by jbdan - 1/30/13 at 10:48am
