AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic GT50 Series Discussion Thread [No Street Price Talk]
Official Panasonic GT50 Series Discussion Thread [No Street Price Talk] - Page 215
post #6421 of 9042
Thanks, I am leaning towards the ST60 because of its value, but what do you think that ZT will cost? sounds pretty amazing
post #6422 of 9042
I can't believe that the ST60 will be noticeable better then the GT50 right now and PaulsTV or Amazon (with price match) is only $999.99 before tax for the 50 inch model with Paul's "SAVE140" coupon. It's what I just ordered. I can't picture spending another ~$200 to $300 for the ST60 in the same size...
post #6423 of 9042
Hi everybody,
I've been researching TVs to death and was waiting patiently for the ST50 to get to $1000, then I waited for the GT50 to get to $1000 (which it now has). I've made several trips to Best Buy (from looking at everything to narrowing it down). I was thinking the VT50 was a bit out of my price range, so I didn't check it out much. However, on Friday I checked out the VT50 and, man, that picture is out of sight. I went back and forth between the two Magnolia home theatre rooms to look at both the VT50 and GT50 - even used "The Dark Knight" on both to compare. I noticed the picture on the GT50 was severely lacking in comparison, but I discovered that it was only connected via component cables, while the VT50 was run via HDMI. Since I couldn't get an accurate assessment, does anyone have any useful feedback as far as differences? The cheapest I've seen the VT50 is around $1600. The VT50 really blew me away, but is it $600 better than the GT50? Has anyone done a real comparison on an even playing field and have any thoughts as far as the disparity between the two? Someone mentioned that the two look very similar after calibration. If i do get it calibrated, it would be a down-the-road thing since this and a new stand, sound bar, etc., will already be a huge purchase.
Thanks for any input!
post #6424 of 9042
Originally Posted by Easywind View Post
Hi everybody,
I also researched them every which way. In most cases, the picture differences are not noticeable, unless you have them side by side. Even then, with most content, it's difficult to see. For me, the room setting was a deciding factor. The VT series handles reflections better (the claim). With windows being a factor in our media room, and a Best Buy display model discount, I went with the VT. The picture is beautiful.
I say, you can't go wrong with either choice. Go for it and don't look back.
post #6425 of 9042
Hi everybody,
I know that CNET isn't the end all of reviews but its what sold me on the GT50 being "great enough" especially at the $999.99 price point for the 50". The blacks in the two sound about the same unless you have them side by side. The extra features of 96hz seemed to disappoint CNET because it introduced some flicker for some reason or something and its not avalible in 3D mode. That makes the GT and VT about the same in 3D mode except for the slight panel differences. If they had a 50 inch VT that was like $1199 or even $1299 I would have got that. But the entry price of +$600 compared to a GT set, it's steep! Even if you do get 5 extra inches, if you WOULD have been happy with 50 inch then you probably will be happy with the GT!
Btw, I just ordered a 50GT50 about an hour ago. I couldn't fork out the extra $600 for the 55 inch VT :P
post #6426 of 9042
Originally Posted by htwaits View Post
Your set is fine. You didn't provide any critical details so I'm going to list my assumptions.
You are watching TV when this happens. Therefor what you are seeing is the edge transmission junk that was always hidden with CRT direct view sets. CRT displays had built in over scan to hide what you're now seeing. Most likely you see it on SD channels, but it's possible to see it on HDTV too. Another assumption is that your display is set to map the input signal dot by dot on your screen. I don't own a Panasonic, but I know that there are two settings that go with the Full mode. They are "something 1" and "something 2". If you're bothered by what you are seeing, just switch the setting and you will get a 5% over scan that will hide the junk. Of course, over scan reduces sharpness and detail slightly.
This problem may not be at the top of repeated questions, but it does come up frequently for all HDTV sets that are capable of dot by dot image mapping. wink.gif
Originally Posted by tpollagi View Post
That thing is an encoded data stream. Its one way to beaming stuff into your tv that is kinda a legacy approach that is still being used. It can contain anything the broadcaster wants to send. Like closed caption data and channel and program information. A little annoying but 100% normal.
Thanks for the answers. I do appreciate it. I didn't think it was something to be too concerned about.
post #6427 of 9042
+1
post #6428 of 9042
post #6429 of 9042
Thanks for the replies. Indeed, this will be tough not having seen the GT50 on a level playing field with the VT50. I'm just wondering if there is any more wiggle room with the VT50 at $1600 - not sure if it will be going much lower.
post #6430 of 9042
If that's the price your getting it at. I wouldn't try lower. As its insanely low to Begin with
post #6431 of 9042
It's been reported at least two times that I've seen that if you have a PaulsTV RETAIL store you MAY be able to walk in and get it for $1497 or $1499. The first one was on the East coast and was an "in store only" discount and the second one was just reported tonight after a bunch of talk downs and different discounts. A $500 "trade your old TV" in discount, then they disregarded actually having to bring in an old TV for the customer and said they would discount it by $500 anyway and then also pay tax so they priced it at like $1415 and then added tax on that to bring it to like $1499.
Good luck with that though and I'm sure phone orders or online wouldn't be able to match that price. Go look in the VT great deals thread if you want all the details. Sounds like a hard one to reproduce though...
post #6432 of 9042
Originally Posted by Bond 007 View Post
post #6433 of 9042
Here is a strategy that may not have been considered.
At least in my market, the supply chain is drying up. I went into Best Buy to purchase a GT and they were no longer available. The manager then tried to get a VT, but that was also difficult. In the end, he offered me the store display model VT with a new factory warranty at a great price.
Some of you that have been waiting for the pricing bottom, may be able to leverage the supply shortage. You might try going to local Best Buys with cash. Cut to the chase and get the store manager to help you. Offer to buy their store displays (either GT or VT), if they will include the factory warranty. This allows the manager to make a sale and remove a piece that he can no longer get. It's a win/win.
They will have to start doing this on there own soon anyway, you are just taking a preemptive action. You could get lucky and score a good to great deal....
post #6434 of 9042
In addition you can check it out for any buzzing. You may hear a slight buzz at the upper right-hand corner (as viewed from the back) but should not hear any from the front.
post #6435 of 9042
...he offered me the store display model VT with a new factory warranty ....
Exercise some caution with store displays. Some of those store demo sets see more abusive behavior in a month than most sets will see in their life. I did not know store managers could issue a new factory warranty on demo items. If nothing else, go over the screen with a magnifying glass and every color slide known to man to look for irregularities.
post #6436 of 9042
For me the big question is...do try to go get a 55' VT50 for around $1600/$1700 or wait for the 60'' ST60 for the same price?
I need to replace a 55'' GT50 that my kid broke! It sounds crazy but I can't fathom shelling out another $1600 just to have the SAME TV! For some reason I will feel better about stepping up in either model or size. So since I will probably not calibrate either, I don't know if I want to pay the same for the slightly better black level of the VT when I can still have excellent blacks AND 5'' more screen with the ST. And the reason I would wait for the ST60 rather than the ST50 is the deals are not that great on the 50's and the new 60's are priced $200-$300 (msrp) less to begin with than last year. Not to mention the new ST60 will look so much nicer than the plastic ST50.
Seeing how much the prices have dropped on the VT50, maybe I wait it out until the ZT is available for half price at the end of the year! I don't think I will be able to tuff it out with the old 42'' LCD projection TV for a whole year though!
post #6437 of 9042
I agree. Personally, I would never buy a floor model plasma...period.
post #6438 of 9042
Quick question, just received my GT50 this morning. All set up and looks fantastic! Just playing around with the picture settings and seeing which I like best, CNET's, HDMaster's.
Question---Tried using VieraConnect and the sound will not play through my 3.1 set up. Hooked up through an Onkyo AVR. I have to turn off the receiver and turn back on the TV speakers to hear anything while watching Youtube or Amazon Instant Video. What settings do I need to change to be able to use my 3.1 setup for VieraConnect apps? Thanks!
post #6439 of 9042
Personally, if there's even the slightest chance that my kid will break the new one, I'd go lower price and bigger screen (just to make me feel better), even if that meant going with the LG or Vizio.
It breaks my heart every time I see you mention your broken GT.
post #6440 of 9042
My IR from playing endless hours of Call of Duty finally faded away. Took a couple of days but its now gone and I am starting to play at the Standard setting which is like playing in the dark.
post #6441 of 9042
I am really sorry to hear about what happened to your set. That's just a bummer. But getting back to your question just realized that if you wait for the new ST60 it still won't be a GT50. It will have none of the THX settings, from what I am reading. You'll pick up a couple of sundry items like a built-in camera and some new apps/options. I'm not sure if that is going to be a software update for the 2012 models though. When I spoke to Panasonic customer service they said that some enhancements were software and it will probably be an update to the 2012 models. Just remember that came from customer service??
On the Panasonic website right now they have the TC–P60ST60 prepurchase price of 1444.99. The 55" is at 1274.99. That is the EPP price. If I were you I would going to Best Buy and see if they would match that. When I bought my GT50 they matched the EPP price and even did a bit better...by $100. I got a super great deal but I did build a rapport with the manager of the magnolia department.
post #6442 of 9042
I just picked up a 50GT50 a couple days ago and I'm wondering why the THX picture modes are not listed when in DLNA mode. If I hit the Vierra Tools button and select one of the THX picture modes and then go to DLNA and start streaming a video, then click the menu button->picture->picture mode and scroll through, I only see Custom, Vivid, Standard, Cinema, and Game. If I exit DLNA to any of the HDMI inputs and do the same thing I get those same picture modes plus TXH Bright Room and THX Cinema as options. Are these picture modes not available in DLNA mode? I can't think of any logical reason why they wouldn't be. That and the fact that I can't pass DTS audio from mkv files in DLNA back to a receiver are the two things that are turning me off about the advertised DLNA capabilities. Any advice for me?
post #6443 of 9042
All store display models get the same exact warranty as if you purchased new in the box.
post #6444 of 9042
Originally Posted by ehfz View Post
... Are these picture modes not available in DLNA mode? I can't think of any logical reason why they wouldn't be. That and the fact that I can't pass DTS audio from mkv files in DLNA back to a receiver are the two things that are turning me off about the advertised DLNA capabilities. Any advice for me?
Correct, no THX modes for DLNA or with the media player and I don't think in the apps either. DTS is not supported. You can remux the audio in the mkv's to AC-3 on your computer if you have to use the GT's DLNA. If you feel you have to stream, then stream to a "box" that is connected to the GT rather than the GT itself. I wasted too much time trying to get streaming to work reliably, scrapped it all, then added a simple media player + hard drive. Simple, reliable, no incompatibilities, 1080p output, and full audio support.
post #6445 of 9042
Under custom pro settings, can anyone clarify what exactly the color space is? I googled that it was actually color gamut, wide seems to make the colors pop out more.
post #6446 of 9042
They may pop more but it is not accurate, wide expands the color gamut beyond the Rec709 gamut, again if you are looking for accuracy not accurate but it may look good to your eyes and that's all that matters in the end.
post #6447 of 9042
My set was professionally calibrated by chad b, he set it there. In addition to the service menu grayscale adjustments he tweaked the cut an drive values in the pro settings as well to account for the wider gamut. The measurement graphs shows color still measuring within target.
post #6448 of 9042
Well if Chad found it more accurate then I stand corrected he knows his stuff I was speaking in general terms. I am familiar with his calibration techniques he has done 3 of my sets.
post #6449 of 9042
Hmm...interesting. I'll see if he can talk to us about it.
post #6450 of 9042
my set has become quite grainy and is having a hard time with dark large field gradations. not sure if it is me or if it was always like that. but the more i watch, the more i notice. fine detail and color is superb, but i'm discovering flaws. i'm using black ops settings, i think. anybody experience this after having the set a while?
just kinda ranting...
