Depends. I ordered on line from them even though they have a local store 20 minutes away. I got a better deal that way. The delivery guys were regular Paul's employees. Very professional, very courteous and familiar with my TV. So if you live near a Paul's that is probably what you will get. If not, I guess it's a crap shoot. If you have to return it though....Originally Posted by synistr
I got my TV from them and it works fine but if I had to do it over again, I wouldnt order from them. I saved maybe a max of $112 iirc. I received my set in 8 days which wasnt bad. Its the delivery by the local agents that is shaky. Once Home Direct gets it to your local agent.....they sub-contract out anybody with a panel truck.....mostly rented on a daily basis to make deliveries from sun up til sundown. So your TV will be squished in with refrigerators, beds, couches, etc....
They dont do any setup, so dont expect it....just take the top box off, turn it on and get you to sign paperwork. The only thing I can say is, the deliverers did know the box contained a TV, anything else...they probably could care less about as they are just getting a flat drop fee. Best Buy was much better. I recommend to spend the extra $100-200 bucks to order from Best Buy or Amazon. I was one of the lucky ones...but you may not be.
I do enjoy your calibrated custom on my set and I also remember you talking about calibrating my custom mode at 75% saturation as that more closely resembles actual viewing content, which the wide color gamut selection ends up hitting on target nicely with the 3 clicks less on the color control.
