AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic GT50 Series Discussion Thread [No Street Price Talk]
Official Panasonic GT50 Series Discussion Thread [No Street Price Talk] - Page 220
post #6571 of 9042
Originally Posted by RandyWalters View Post
If you happen to get one that buzzes beyond a few feet then it's either out-of-spec or has an internal defect and needs to be returned, replaced, or repaired. Period. The vast majority of us 2012 Panny owners have perfectly silent TVs.
+1
post #6572 of 9042
I hope (fingers crossed, knock on wood) that I'm part of the vast majority that does not have a GT50 that buzzes smile.gif.
Bill
post #6573 of 9042
The GT50 doesn't have a "buzzing issue", no more so than any other model or brand. Buzzing is a side effect of one of several different possible defective components inside a Plasma TV and all brands and models have experienced those random defects since the first Plasma TVs became available in the late 90's.
Thanks Randy!
p.s. you should check your pm's, lol!
post #6574 of 9042
Originally Posted by Iain- View Post
BTW, the steps of gradation are the only thing I'm sceptical of on GT50.
Is this noticeable or is it simply more marketing fluff?
Last year when D-Nice was evaluating his example GT50 he said the 24,576 Steps of Gradation wasn't noticeable over the ST50's 12,288 steps. If he can't see the difference, then none of us can wink.gif
Further thoughts of this.
Could this SoG issue be down to quality of source material, similar to the way "1080P Pure Direct" is?
Also, could "1080P Pure Direct" be working concurrent with SoG to produce the superior PQ results I'm seeing?
Wonder what D-Nice source material was during his evaluation?
Edited by Iain- - 2/15/13 at 7:39am
post #6575 of 9042
Further thoughts of this. Could this SoG issue be down to quality of source material, similar to the way "1080P Pure Direct" is?
He was using test patterns. I also remember him saying the GT50's increased SoG also increased dithering compared to the ST50 which kind of took the wind out of my GT50 sails smile.gif
That's when i resigned myself that the GT50's PQ was going to be no better than that of the ST50.
post #6576 of 9042
Hello Gents
I just took delivery of a P65GT50. It's sitting in the entryway warming up (36 degrees out today) before I put it into position.
I picked it up through Amazon and I was able to finagle a price match from last week. I had to return a Vizio 70" that I couldn't stand and the return took longer than expected because Ceva sucks here in Columbus. So amazon was gracious enough to honor the earlier price.
It is replacing a P50G15 and the aforementioned Vizio 70" that I had for all of 6 days. I couldn't even finish watching the Super Bowl on the Vizio, at halftime the wife and I re-installed the P50G15.
No real questions yet, I've skimmed the thread but I need to go back through and hit the high points. This is my 3rd Panasonic plasma, I also have a P42C2 to go along with the P50G15. Let's hope the 65 is as good as my other two, because they have been nothing short of excellent.
post #6577 of 9042
Gents
As I mentioned i received my second gt50 panel. Picture is much better than first. However one difference I notice is that when i set to Full and HDMI 2 I get some strange white lines around the edge of the picture at times. Not sure if it's the content i'm viewing or another setting. Is this normal?
post #6578 of 9042
just got this tv today. for whatever reasons, i'm unable to pickup digital channels. i tried auto program for cable and antenna. neither works. both shows 0 digital channels after 100% scan. it's starting to annoy me since i'm worried about image retention while the autoprogram is running. is there a possible problem with the tuner? my coax cable is working fine with a different tv.
post #6579 of 9042
Try tuning a strong station manually.
post #6580 of 9042
My GT50 pulled in all the digital QAM cable channels from the wall just fine. Then i later erased the cable channels and re-scanned my digital antenna channels and that worked fine too. It can be a little tricky to save the channels after the scan completes so maybe you left out a step.
And you have to scan for the type of source you have. If you have basic cable service from the wall, selecting Antenna for your scan won't work at all. Make sure you select Cable for cable, and Antenna for antenna. You can only do one or the other - the tuner won't remember both sources together.
One problem though is that if you screw up a scan, the tuner won't retain subsequent re-scans so i've found it best to erase the corrupted scan by disconnecting the coax from the TV and running a new scan which will "erase" the corrupted data, then once that completes re-connect the coax and do another scan which will import the channels. Make sure to save it before exiting.
post #6581 of 9042
I do have cable at my place, but setting it up without the cable box. So I tried scanning with cable selected first, it gives me 61 analog channels, 0 digital. So I went ahead and tried antenna, same thing, 61 analog and 0 digital. I'm gonna try your method of disconnecting coax and scan, then reconnect coax and rescan. I really hope there's no problem with the tv.
post #6582 of 9042
When you reconnect the coax and do a re-scan, make sure you select CABLE, then ALL CHANNELS, then let it scan for about an hour. I believe it scans the analog channels first, then the digital channels after that and the digitals take a LOT longer. Sometimes after say 20 minutes the scan hangs and it looks like the scan has completed, but it actually has not imported the digital channels yet so you may have thought it ended then exited too early. It takes a LONG time to scan for the digital cable channels because there are dozens if not hundreds of blank channels that slow the process way down. When you're sure it's done scanning, you have to save it (i think you select "Apply" or something like that) to make the channels stick.
If you're concerned about IR from the scanning menu being up on the screen for so long, maybe put the TV into STANDARD picture mode with the Contrast set all the way down so the screen is very dim.
post #6583 of 9042
My GT60 went into a gray screen saver mode after 5 or 10 minutes during the scan so IR shouldn't be an issue. You can hit any button on the remote to check the progress of the scan. As Randy said it takes a long time but you will know when its finished because it will switch to the lowest live channel after its done.
post #6584 of 9042
I was just looking at pictures of the inputs on the 60GT50. It appears that the component input is not the standard three RCA (Red, Green and Blue) input. Is there a special adapter needed to use the component input? If so does the adapter or cable come with the 60GT50? I use component from my SA 8300HD cable box direct to my display and I plan on still doing that if I can.
Bill
post #6585 of 9042
Component adapter is included.
post #6586 of 9042
Thanks, Eric smile.gif. It looks like the best bet will be to use HDMI. I was using component as it helped with the delay between cable channel changes. Is anyone using the component input on the GT50s? If they are does it accept 720p and 1080i? Also what is the length of the power cord?
Bill
post #6587 of 9042
Thanks for the help guys. I think that's what actually happened. It was at 100% for a long time and I assume it was finish and exited. The channels are working fine now.
I have 2 other questions though.
1) is the side of the tv (specifically the chrome part) suppose to get really hot after tv being on for couple of hours?
2) this might be just me since i'm going from a xbr9 led after 3 years to this plasma. my htpc is connected to this plasma. when i'm watching mkv files, the picture sometime acts funky. i'm not quite sure how to describe it. something like a combination of lag, skip, shutter, jitter. just some scene is not very smooth. i'm using the thx brightroom settings. is this something i'm not used to yet or is it a problem with the settings?
post #6588 of 9042
Bill
The stock power cord is about 5 ft. which is pretty short. I picked up a 15 ft. replacement from monoprice for $4, it has the correct right angle plug for the TV end. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022809&p_id=7678&seq=1&format=2
post #6589 of 9042
Eric,
Thanks again for the information and the link to Monoprice. At 5' the power cord will be way too short for my installation. You would think that Panasonic would at least provide an 8' power cord.
Bill
post #6590 of 9042
Eric,
Bill
Yeah I agree, especially since it plugs into the middle of the TV so you loose over a foot before it reaches the base.
post #6591 of 9042
I've had my 60" on for about 3 hours today running break in slides and the sides are cool and the top is only slightly warm.
post #6592 of 9042
I ordered my 60gt50 from Paul's yesterday for 1699. Still hasn't shipped yet. Im hoping they didn't run out of stock out something crazy like that lol.
For those of you who ordered from them was it a pleasant experience? How long did it take to ship?
post #6593 of 9042
Eric,
Bill
I was surprised at the short length too. My 3yr old Panny had a 10 ft cord.
post #6594 of 9042
I spoke to the tech that will be servicing the "buzz" in my TV this upcoming Monday. He acknowledged that the buzz is a common problem on the 2012 Panasonic plasmas. He even asked me if the sound was originating from the upper left when viewing the TV... which I acknowledged. He said it is coming from the SS board and he will be replacing all mounting screws for that board and a second board. The original mounting screws apparently do not properly ground the boards. The repair will take about 45 minutes.
Fingers crossed... if this fix doesn't work, the TV is going back to Amazon. I don't want to return it, but the buzzing makes cringe any time there is a bright scene.
post #6595 of 9042
Originally Posted by LoD80k View Post
Gents
Your TV is normal. You are seeing something left over from the old SDTV/CRT days when overscan had to be built into all TV sets.
Most Panasonic Viera TVs have a setting called "HD Size". This will switch the TV from overscan to a 1:1 pixel mapping. I think that Full with HD Size set to "1" will give you a small amount of overscan. Changing the setting to "2" will zero overscan. Pioneer used to call that setting "dot by dot".
You can read about the history of TV and overscan here.
HD 101: Overscan and why all TVs do it
By Ben Drawbaugh posted May 27th, 2010 at 2:43 PM
post #6596 of 9042
I had heard so much bad stuff about this screen (coming from an LCD/LED) that I was ready to return this thing the moment it arrived. You can imagine my surprise when (1) it is totally silent, (2) there is virtually zero IR (only for like 2 seconds when the tv starts up and there's the panasonic splash screen) and (3) the picture is sublime, uniform, and rich. Gaming is fine, sports are fine. I really can't find a fault with this TV other than that (1) the color is a little dark (remedied by THX bright room or any other high-contrast setting, I've found) and (2) it doesn't play DIVX files (SERIOUSLY?!?!). Other than that, awesome.
post #6597 of 9042
Glad to hear you are enjoying it!
post #6598 of 9042
Originally Posted by headlesschickens View Post
Unfortunately game mode enables some dynamic contrast you cannot disable. It's not unlike the results you get if you forget to disable it in custom mode. The input lag is quite bad in any other mode so it is very disappointing that no one has ever found a way to disable it.
Actually there is a way to disable this dynamic contrast crap. Go to hdmi settings then to content type and switch to graphics. Instantly the dynamic contrast is gone now can someone please calibrate game mode on this tv and post the settings? Right now im using d-nice's settings but if someone could get close to those using game mode, i would love to play god of war ascension using game mode calibrated to d65. The only downside to game mode is that you cant adjust white balance unless you go into the system menu. Experiment guys.
post #6599 of 9042
Just a quick question. I've read that the PQ between this and the ST50 is virtually identical, but I've also seen that the ST50's can get brighter than this model. I'm wondering only cause I can't find a 60 inch ST50 anywhere, but 60 inch GT50's are scarce but around and I really want a 60 inch TV this time around. Are a calibrated ST50 and a calibrated GT50 virtually identical?
post #6600 of 9042
The ST50 and the GT50 were $400 apart in price. Some questioned the value difference at that price. If you want a ST50 and can't find one, but you can find a GT50 for about the same price why not buy the GT50?
