Originally Posted by crow216
I really need help setting up my panel fellas. I've been tweaking and messing with it for 2 weeks. The THX Cinema is beyond dark, even at night with no ambient light around. The THX Bright Room is bright but the colors are completely washed and don't pop at all. I've tweaked cinema the best I can but it seems that my desired brightness level only comes from having the panel brightness set to high. As you all know, that also destroys skintones and makes them look unnatural.
Do any of you have a solution? I'm looking for the brightness and color that vivid can provide with a little more skin balance. Sorry for making my first post so painful but it's entirely too hard to read hundreds of pages on here and believe me, I have tried.
Any help is much appreciated.
Dial in HDMaster's settings. If the image is still to dark then I have to suggest a different TV or a replacement. THX Cinema is actually pretty good. If you think it's way to dark then there just isn't much more room for increasing the brightness. Brightness really should not be a problem unless you are used to looking at an LCD in a completely blown out torch mode. Within the past week someone was complaining that bright spots like headlights were so bright it was burning his retinas ! Check to see if you have the power saver turn on. It will destroy the brightness.
Edited by tpollagi - 2/24/13 at 5:33pm
