Originally Posted by
ser_renely
Bond 007
Its not going to give you better pq or sq. If youre not having any problems you probably would see no benefit. Use some good quality surge protectors.
I understand that, I was thinking along the lines if it does create "better" power, than the life of the equipment may prove better.
The life of your equipment will be effected by surges that get through to them. "Cleaning" normal power will have no effect either way. If your power is unstable, with frequent brown outs, then a UPS can protect you from damage.
I don't know what "better power" might be.
