Originally Posted by
CobaltDragon
Does anyone now if you can uninstall an app from the TV? I know you can uncheck the box and it won't show up on the picture menu, but I'm wondering if an app can actually be uninstalled.
Starting about 3 days ago Netflix stopped working. It starts up and displays the logo on the red background and just freezes and eventually says it can't connect to Netflix, and to retry or exit. Netflix works fine on the xbox, bluray, or roku so I wanted to try uninstalling it and redownloading it - that sometimes fixes issues with android apps, and I imagine this is a similar system. Other apps work fine, including Youtube and Amazon video, so the network is still operational.
To fix this issue on my TV a while back I followed these instructions. Really it works even though it looks like a video game cheat code.
Launch the Netflix app.
Using the arrows on your remote, enter the following sequence:
Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
Select Deactivate and exit the screen.
Restart the Netflix app and sign in to your account.
https://support.netflix.com/en/node/461
