First off is there a dish only thread in here anywhere, couldn't find one.
I have no idea about dishes, never had one. I always have had digital cable and currently have no cable just my htpc netflix etc. Been toying with getting a cable card tuned for awhile.
What are my options as far as sattelite dishes and are the big ones still available, is that the c band and the c k/u band people talk about? Also what is 4dtv? Which has the best/highest bitrare 1080p signals and most hd channels? Is there any diference between services as far as having 1080p only available on VOD and the other having regular network 1080p? Does one company have better DVRs, does one have better reception in bad weather given everything is equal in hardware and location/position of unit(it would just be up to the band/frequency then, correct)?
Any other options I didn't mentioned. Or know about and any other features, hardware, problems, channels, pros/cons etc. I'm not thinking about?
Thanks in advance.
Thanks in advance.
I'm glad I live in a cave.
