Originally Posted by LTD02
"The LMS is nearly 12" deep, and you can't put a brace directly behind the magnet because I'm sure there's a vent back there. So if you move the brace 3" off the back of the LMS, you now have one stick brace dividing a panel into 15" x 23" and 5" x 23". I think a 15" x 23" panel would need extra bracing?"
roger and considered that. that is why i put in the angled cut in the cutplan. plenty of spacing between the brace that i suggested and the drive.
in this concept, there is no 'stick' bracing.
the gray area is the removed material. the white panel on the right can be rotated 90 bottom toward you, then 180 degrees to the left and will slide into the other panel for a simple effective fit/brace.
if the design has been finalized, that's cool.
i thought this was a design thread, hence my comments...
There will be different designs. The Baltic birch cabinets will likely have bracing like we discussed in that thread last year. It's similar to what you drew out, but it adds a little more.
I promise, I've been working on about 20 different bracing ideas. It's been discussed here for years and I do realize what's needed and what is considered overkill. but for the general public, it has to also look impressive or I will be stuck with a lot of boxes. It also must be able to be assembled by a 12 yr old.
I'll get the photo up of the other bracing we all tweaked last year.
