AVS › AVS Forum › A/V Control & Automation › Remote Control Area › IR repeatter with out MINI??
post #1 of 4
Guys or Gals..
I am looking for an IR repeater that doesn't use 1/8 out to the emitters.. I have an older system (actually the guy who had my job before me made one that uses 1/4 inch outs).. I don't think I will be able to find that, but I would like to be able to find a system that uses bare wire out to the emitters.
Any help is appreciated.
Cheers,
Scott
post #2 of 4
You can check out one of these.
http://www.amazon.com/XANTECH-RT16-1.../dp/B000P0UE2Y
http://www.amazon.com/XANTECH-RT8-Ad.../dp/B000BR3FJK
But still need I an IR receiver kit as part of it.
post #3 of 4
Thanks.. you wouldn't think it would be that hard to turn on a projector.. except when it is 130' away!
post #4 of 4
Wow, that's quite a distance. Is this an existing setup that you are trying to modify?
  Back to Forum: Remote Control Area
