Originally Posted by
PlasmaPZ80U
would the spectro be any more accurate than the profiled colorimeter for gamut work?
Possibly, could vary by colorimeter...? I know I trust the i1Pro over my i1D3 for gamut even though the claims are the D3 could be better on certain displays. I am on D3 number two and each had different readings (no profiling).
airscapes
If you talking about the the i1pro and the C6, not much difference once profiled. The dark reading is not an issue, you set the button on the side of the i1pro to initialize within calman, then when you need to, cover the hole with your finger and hit the button.. done..
That's exactly what I do but it's still kind of a pain if you are going for consistent reads from the same exact spot on the screen. I created profiles both ways, both meters on screen at once right next to each-other and then one at a time in the same location (which is the correct way to do it). I discovered that moving the i1Pro even slightly would change the reads a little. Obviously this is easier with projection having the meters secured to a tripod but with an HDtv it's kind of bothersome to have to initialize the Pro every 10 minutes. especially considering the goofy panel mount that the i1Pro comes with (obviously not intended for large hdtv's as I barely hit the middle of my screen with the weight sitting precariously on the top edge of my thin 60" LED LCD, thank goodness my plasma is smaller @ 50" or it would not work since it's even thinner).
I'll definitely be grabbing the Pro2 down the road once the prices are more reasonable for an enthusiast/hobbyist.
Jason
