AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › fastforward in WMC on 360
post #1 of 6
I have an original 360 windows media center remote (long white remote) and am unable to fast forward through movies playing on the 360 thu WMC, the ship button advances the movies by 30 seconds, is there a way to use the fast forward/rewind buttons on this remote.
post #2 of 6
If I recall, it all depends on the file format. Some formats for example, straight MPEG2/AC3 in a MPG container hates FF/RW. WMV plays nicely with FF/RW.
It's one of the many reasons that MCE is kind of terrible. Do you also have a PS3 by chance? While the system overall is a piece of crap, it does make a far better local streaming device than the 360. It also makes a far worse interwebs streaming device.
post #3 of 6
yes, have ps3 also, looking at same files (all mp4s, as i needed a file format able to play on many different devices) ps3 does fast forward much better than 360.
post #4 of 6
Stop using MCE then. Setup PS3 Media Server on your PC and use your PS3 instead.
post #5 of 6
have multiple tvs with different streamers, trying to get the best solution for each, using the same mp4s
post #6 of 6
Will the files play through the dashboard instead of MCE? The dashboard does FF/RW far better than MCE, but it's picky about format. The dashboard just needs a DLNA server to see, which you're likely using for another one of your streamers already.
  Back to Forum: Xbox Area
