AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Old NuTone 3-wire intercom radio
post #1 of 12
Is there any affordable way (rental house) to use this system with digital content? I was thinking of running a the second zone from my receiver to this and piping it through the house using the existing wire. It's a just a temporary solution. Is this possible?
Thanks in advance
Brett
post #2 of 12
Does the unit have an audio input? I'd think either directly connecting a Sonos (if there's an input), or a Sonos plus a personal FM transmitter (if no input).
Jeff
post #3 of 12
No Audio input (at least on the outside) It's pretty old. I didn't think of a transmitter, that might be the way to go. Great idea.
post #4 of 12
That's pretty old. Does it still work well enough?
You may just want to consider 2-3 zones of Sonos.
post #5 of 12
It works great actually. I just want to get rid of the radio and or update it using the existing wiring while not spending a ton of money.
post #6 of 12
Yeah, just an FM transmitter, one Sonos box, set up a Pandora 80's mix channel and it'll be just like new!
post #7 of 12
Maybe you can hang an old, beat up, cardboard box over the master controller, so it will look nicer.
post #8 of 12
Or a museum plaque next to it explaining its historical significance...
Been very tempted to put one of these up in the back yard:
post #9 of 12
Why not replace the master unit with a new Nutone model? The NM100 will work with the 3 wire and has 2 inputs to add to the tuner.
post #10 of 12
Ha! This gave me a good laugh. Too bad it's not like the hot tub time machine
I'm pretty sure if I push it hard enough it will just fall in the wall. At that point I can probably tie cans to each end of the wires and just have the intercom! Man I hate renting.
If it wasn't a rental I would put some money into it but I wouldn't throw anyone more money at this place. If I could take the nm100 with me and know that I would use it, it would be a great suggestion so thanks.
post #11 of 12
Sorry, I didn't see that it was a rental home.
post #12 of 12
In full disclosure, my old, unused, dead M&S intercom looks similar, and I own my house.
Just waiting for the kitchen remodel to start.
  Back to Forum: Home A/V Distribution
