AVS › AVS Forum › Display Devices › Display Calibration › Rec 601 Discs
Rec 601 Discs
post #1 of 4
I'm thinking GetGrey is the goto standard for 601, just as AVSHD is to 709. However, I'm looking for a standard definition calibration disc that I can leave behind with people I calibrate for. I can't do this with GetGrey due to licensing restrictions. Are there any decent calibration discs out there for 601 that are free?
post #2 of 4
ChromaPure Free Calibration Disc (NTSC DVD)
https://www.chromapure.co.uk/calibration_dvd.zip
This is a basic calibration disc that can be used for calibration using the Chromapure software (or other) and a meter. If you don't have a meter you can try to set the basic controls like brightness, contrast etc.
post #3 of 4
Would it not make more sense to leave behind a list of settings rather than a disk? What is the reasoning.. just marketing? Something for the customer to hold in their hand when you are done?
post #4 of 4
Added value. Even if it is nearly 100% perceptual.
Edit: And it's not merely perception in this case. They can use it to do the basics on their other displays themselves.
