AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXES6100 Thread
Official Samsung UNXXES6100 Thread - Page 10
post #271 of 856
is the UNxxES6150 from Costco or Sams same as 6100? If not, what are the differences? Can I use the same calibration settings that were posted earlier?
post #272 of 856
Originally Posted by redtilldead View Post
I'm having some issues regarding the aspect ratio (i.e vertical black bars).
I am playing content via HDMI cable but there are black vertical bars showing. Admittedly, the broadcast is SD, however, I am using the 16:9 setting on my TV but still get the black vertical bars. Even If I play around with the settings in screen adjustment, the aspect ratio changes but the vertical black bars remain where they are (even when choosing 16:9 or screen fit).
The screen "fills up" fine during BluRay/Smart Hub & HD content.
Everything was fine when I bought the TV (i.e. screen would "stretch" to remove the bars), the only tweak I did was doing some calibration (JaVae's settings above).
Can anyone help me out on how to get rid of the black vertical bars when displaying SD content?
P.S. the screen stretched fine in my old Samsung TV.
make sure you are not using the sreen fit picture size mode......use 16:9...also check if you need to change the settings in your tv decoder.
post #273 of 856
Thinking about using this tv as a computer monitor the 40 inch version any thoughts?
post #274 of 856
http://reviews.lcdtvbuyingguide.com/samsung-lcd-tv/samsung-un46es6100.html
I was reading the review for this model on the website linked above and for a number of reasons, I don't think that source is reliable or accurate (technically speaking at least). It mentions things like "black saturation", "D65K", and the following:
"While we initially thought that this panel would by the Ultra Clear Screen technology that we liked so much in 2011 it is actually a semi-matte finish screen. As a result there is poorer side viewing angle quality in this TV as all matte type LCD screen finishes diminish contrast and saturation at side viewing angles. While this treatment does cut down on reflection from the screen, there is glare off the screen from in room light.
As with any LED/LCD TV with a matte or semi-matte screen finish your viewing angles are going to suffer. The ES6100 is not worse than others in this area, in fact it may be better but contrast/saturation diminished by around 20% at 25 to 30 degrees off center. Stay front and center for the best results from this TV."
I've never heard anything before about a matte screen finish hurting viewing angles and PQ at those angles. Sounds like nonsense to me and makes me wonder if this site holds a candle to CNET or Consumer Reports. Anyone else find this review site questionable?
Also, on a completely separate note, does this TV do 3D? The review says it does but the Samsung website does not.
post #275 of 856
Read some of the other reviews on their site. Some of them don't even sound like they had the actual TV with them for doing the review.
And I don't think the matte finish is what causes the viewing angle problems. It is Samsung S-PVA panel tech combined with their edge lit design.
post #276 of 856
post #277 of 856
My TV is set to 16:9 and the cable box is also on widescreen. But I'm still getting black vertical bars as if the display is 4:3 (this is with HDMI connection). HD channels are OK but cant get the SD channels to fill the screen,
On the other hand, when I connect through composite, I get 16:9 display but it seems as if everything is "zoomed".
Please can someone advise how I can fill the screen with HDMI connection?
post #278 of 856
I thought the same thing! The review talks about the 3D quality viewing when I'm almost 100 percent positive it does not have 3D. Amazon doesn't mention anything and the Samsung specs specifically state it is only 2D. What a horrible review! Does anyone who owns this set confirm this?
post #279 of 856
This set is definitely 3D if you want i can even make a picture of it smile.gif. Avatar in 3D looked awesome.
post #280 of 856
This set is definitely 3D if you want i can even make a picture of it smile.gif. Avatar in 3D looked awesome.[/quote
All I know is I just went on the Samsung website and looked up this model number and no place in the product description does it mention 3D. The 6500, 7000 and 8000 all have it. But I am not seeing anything that says the 6100 is 3D.
post #281 of 856
post #282 of 856
Some non-US models have different feature sets. I do believe they are reviewing these models.
Edited by ocellaris - 7/23/12 at 7:36am
post #283 of 856
Another reviewer who owns an ES6500 said that the viewing angle on the edge light Samsung ES6x00 is dreadful to the point where his couch only had one good viewing seat. And the couch was literally centered in front of the TV, 10 feet away. Also the CE Dimming was highly annoying, and when you switch modes to disable it, you may get a lot of clouding and other uniformity problems.
Has anyone who owns the ES6100 experienced similar issues?
post #284 of 856
if you look at reviews for ES series Samsung LED-LCDs on CR.org, you'll find the viewing angles evenly split between 'narrow' and 'moderate'... think LCD panel lottery, some LCD panel types/versions have worse viewing angles than others
what you described is definitely a narrow viewing angle, so narrow that the TV is basically useless for more than one seat on the couch... I imagine larger screen sizes would be affected the most
post #285 of 856
I kind of settled on the UN40ES6100, so I went to Best Buy and looked at it. The display model had noticeable bright spots near the corners. See above. The bright spots in the lower right are about the size of dimes; they looked worse in person. (The spots near the laptop image are just reflections of the store lighting.)
Other than that, the picture looked fine. Is this typical for the ES6100? Don’t know if I’d want spots like that after spending $800.
post #286 of 856
i don't have any of those spots... def. not "normal" or acceptable.
post #287 of 856
So I guess the advice is to buy one and keep my fingers crossed that my TV doesn't have a similar defect...
post #288 of 856
post #289 of 856
I bought the UN40ES6100 last night. The screen is fine (I would say perfect, but you guys probably have a different definition of "perfect" than me). No bright spots. I turned off the auto backlight adjustment because it was very annoying and the screen was too dark with the auto adjust on.
Now I have to get the WiFi streaming set up properly. Samsung's AllShare server was crappy. The TV works with the Win7 / Windows Media Player streaming, but the setup is clunky and I have to rename MKV files to WMV for them to play. Also, there's no real FF/rewind function.
Any suggestions on a better DLNA server than what's built in to Win7?
post #290 of 856
That would explain a lot since my 60" definitely does not have any 3D capabilities.
post #291 of 856
How did you turn off the auto backlight adjustment? Previously I thought we found it was only done by setting picture mode to "movie".
post #292 of 856
I think that poster meant the eco sensor or energy saving auto feature (whatever it's called on the 2012 sets, I don't know the exact name).
post #293 of 856
At least on the ES7100 you go to settings -Eco sensor -off-on. If on you can adjust the minimum backlight setting. This will remain in place till the backlight is adjusted in the main menu picture settings then it will revert to off and you have to go back and cut it on. I keep my minimum around 5..+or -1
post #294 of 856
Menu - System - Eco Solution - Eco Sensor set to Off
That's the only setting I changed. The varying backlighting was really annoying and generally too dark. There's a minimum backlight setting, but I didn't try changing it.
I'm pretty intimidated by all the other settings, so I left them alone.
post #295 of 856
I find the minimum backlight setting to be a key part of my set up. But you don't want it too low as it becomes too noticeable during changes.
post #296 of 856
Hi,
I'm testing a 40ES6100 for a specific use and I'd need to disable all wi-fi capabilities on the device, especially the wireless signals the TV is emitting for direct connect purposes.
I've gone through all the menu settings and couldn't find any way to disable the wi-fi capabilities.
Does anyone know how to do this model, or on any new Samsung 2012 models?
Thank you
post #297 of 856
On the ES6100, what's the difference between Auto motion plus and LED motion plus? Both say "Optimize screen for displaying fast action scenes".
post #298 of 856
frame interpolation vs. backlight scanning
post #299 of 856
LED motion plus reportedly strobes the LED backlight, doesn't have much effect to most.
Auto motion plus controls the frame interpolation that can produce the so-called "soap opera effect" from 24fps movies. Some hate it while others like it, but you can adjust it to your personal preference.
post #300 of 856
OK, thanks, guys.
