Originally Posted by Centinul
Just a bit of an update.
Problem
I have a PC hooked up to the TV via HDMI. When the HDMI input type is set to "---" the picture looks great but there is extremely noticeable flickering when transitioning between light and dark scenes.
When the HDMI input is set to "PC" the flickering disappears but I can't configure the TV settings to get an acceptable picture. There is very noticeable clouding.
Things I've tried:
I tried hooking up my Roku LT. This did not exhibit any problems whatsoever. I'd be inclined to say it's my PC but I disagree for two reasons:
Anyone have any input? What different type of processing does the TV do when the HDMI input type is changed?
Problem
Things I've tried:
- Updated the firmware
- Updated my GPU drivers
- Switched HDMI cables
- Switched HDMI ports
- Before I had this TV I had it hooked up to a Samsung LNT3242H with no problems
- I would expect the flickering to be present regardless of the HDMI input type selected on the TV
I can ck this with mine, this weekend. i have not hooked up any hdmi as of yet. you made the adjustments yet to try to reduce the clouding? there is a link in this section that shows recommended settings. "if" you have another way of cking the inputs, via another source of output (pc) then test this. is it within warranty? if so, you'd have an avenue of exchanging.
