I am looking for a Low-Light HD Camcorder for quick low light / Night shooting.
I would like to spend as little as possible but due to my requirements I realize that it is very hard to achieve cheaply.
I just got access to a T3i that I just shoot on auto. I realize I can potentially use this but the objects that I want to capture are not stationary and the sightings are infrequent.
I would most likely never be able to set up a tripod in time to obtain video.
The viewings are random and quickly over for the most part.
I have seen 3 distinctly different objects and it is time to get them on some sort of footage.
I would need to be able to capture quick nightime shots.
Luckily I wasn't alone and the objects were seen by others when I called them to come see.
I would REALLY appreciate any serious suggestions.
My budget is $1500 to $2500 most likely.
Thanks for any responses.
