I'm cleaning-out my basement, and I have an old tower system with Windows XP that I haven't used in years. The only reason I keep it is for if/when I need to replace another Replay drive.
My question is, can I use a current Windows 7 laptop to Patch a drive if I use a USB to IDE converter like this one http://www.newegg.com/Product/Produc...82E16812232002 ?
Also, what are the chances I'll be able to actually find a hard drive to put into the Replay?
It's getting tougher to know if its worth hanging on to the Replay lifestyle, or when the next drive goes should I take it as the sign to move on to another technology
Thanks for your thoughts on this...
