AVS › AVS Forum › Audio › DIY Speakers and Subs › Wanted BIG BASS: Big room open to an even bigger room with lots of windows!
Wanted BIG BASS: Big room open to an even bigger room with lots of windows! - Page 2
post #31 of 144
Originally Posted by Chassmain View Post
No doubt, if there was a basement it would definitely between two of your horns and a quad 18 infinite baffle set up. That being said I quite enjoy/appreciate all the solar gain these black tiles soak into the concrete on a cold, winter day.
Been thinking about doing something along this line, although with probably only 3 enclosures, 6 Dayton RSS390s total. I could place one at each corner of the front of the room, and the remaining one near field behind the couch. In such a big room with this give enough output/pressurization?
And beyond that, are these relatively inexpensive Dayton subwoofer's at a sound quality level where they wouldn't diminish my 801s?
That sounds like an Ideal sub system for your marvelous room. The sound quality of the Dayton subs are superb. Comparing the sound of them to a commercial sub I would say the sound like the Velodyne DD18 and JL Audio F113, if you've heard those. My Dayton subs are a great match with my Aerial Acoustics 7B's so you'll have no worries there with your 801's. Even good 300-500 watt plate amps will drive these units fine. Of course something can be said for kgvet's recommendation too.
post #32 of 144
The builder of Sublimator! I have followed your build closely, and if I go the dual opposed Dayton route the building will be very similar to yours. Having just finished a set of your own, maybe you can put to rest my biggest concern. Will there be enough output?!?
With the humongous room, and the many LFE suckouts (i.e. 150+ square feet of glass, multiple doors into multiple rooms) will I have enough output? The last thing I want to do is spend all my money building these subs and still be wishing for more.
post #33 of 144
Originally Posted by paulspencer View Post
Lovely room! I think we're all extremely jealous.
Thanks! Definitely means a lot!
I'd be inclined to do a series of tapped horn modules that go across the front wall, their height matching the sill height and running all the way across. Drivers chosen to suit the profile, whether that be 10,12,15" drivers, ideally dual opposed for the reduction in vibration. I'd shoot for 20 Hz and run an active crossover and do some measuring to assist with combining the existing bass with the subs. Could be a fun project.
Paul/tgs!
Your posts kept me up half the night thinking about possibilities! An integrated window seat spanning across the entire front of my room! That would be freaking fantastic! It would blend nicely with the décor, provide a useful resting place for my pup/friends, completely hide my oh sh** that's a lot of bass and not obstruct my view!!!
Now what to do Sealed, sealed, sealed or a couple smartly placed horns.
So the dimensions I have available The distance from the floor to the windowsill is 19 inches From the front wall to the sliding door frame 18.5 inches. What I'm thinking is to build something that spans across the entire 23 feet of my room.
So I've get 23' width x 19" height x 18.5" depth. Somewhere in the center I'd like to integrate a B & W HTM Matrix Series center.
Little more research and I find the Danley DTS 20 Tapped Horn subwoofers almost fit into these dimension perfectly at 87.5" x 18" x 20". What about two somethings similar to these with the mouth firing out of the corners facing me? There is no way I could afford two of these beasts, but there must be something someone else has already designed that is similar.
What about using horns Will I be giving up anything sound quality wise as far as distortion/musical accuracy? I'm just getting up to speed on the whole theory/what's involved, but the engineer in me definitely likes the idea of doing more with science!
Any proven narrow profile, but wide horn designs out there in existence? I could easily go as wide as a full sheet of MDF or more! Just need to keep the height/depth under 19 inches.
I'm plenty open to designing something of my own, but have a huge amount to learn HELP! :-)
post #34 of 144
With a limited budget, horns will get you more spl per $$ than anything else, IF you can spare the space, and don't mind the loss of extension. With $1500 in the budget, you can build approx four 15" loaded 20-22Hz basshorns (F20, THT, etc) and an amp to power all of them. For a slimmer profile, look at the THTLP or think of a group of tall tapped horns:
http://www.volvotreter.de/th.htm
Soemthing like what paulspencer described, 15" loaded, tuned to 20Hz. Tapped horns almost always need highpassing, unless designed very well.
How loud are you thinking of running? How low? Full reference? Less? Where do you listen now, dB-wise? Deciding that should narrow your choices.
JSS
post #35 of 144
the sealed cabinets tend to be the least sensitive and so require the most drivers and amps. they are great for small-medium sized rooms where the gain of the room is about 12db/octave and matches the natural 12db/octave rolloff of the enclosure.
the ported tend to employ larger cabinets, have increased sensitivity and max spl vs the sealed down near the tuning frequency.
horns tend to be relatively huge, but can take advantage of the driver loading to come very close to theoretical maximum efficiency, so they have the smallest amp requirements and produce the highest spl.
three w15gti drivers are presented for comparison. sealed and ported in winisd. the sealed cabs use about 12 cubic feet total, the ported ~24 cubic feet+, and the horns shown in hornresp use about 60 cubic feet total.
all are setup for 2000 watts total as the limitation on the amp (666 watts per each of the three drivers), and ~20mm xmax limitation on the drivers.
at 20hz, you get 114db with the sealed, 124db with the ported, and ~131db with the large horn.
post #36 of 144
Not if the design is halfway decent. I prefer the sound of either one of my horns over the sound of the IXL 18" build that came before them.
I wouldn't run any TH or even any horn in general without highpassing, to be honest. Problems with excursion below F3 aside (and that's a big problem on a TH design), you also run into issues with the harmonics being amplified by the horn over the fundamental.
post #37 of 144
Okay Just pulled out the RadioShack digital meter and listened to some music. At more or less I'm listening to loud music while I work away it's normally around 85-90 db at listening position. If I really want to crank it up it's about 100-105 db at listening position about 15-16 feet from the speakers.
When watching movies I'm right around 100+ db, probably -10 reference or so. Keep in mind this is a good 15-16 feet from the speakers.
How low? Right now I'm just going as low as my 801's will take me Anything below would be a huge plus, but I think the lowest that I can go while still maintaining a SAFE headroom is what I want.
Looking at LTD02's simulations, especially keeping in mind that he's using w15gtis which are far more capable/expensive then the Dayton drivers, I know I'd definitely be running out of steam with the sealed setup (-12 db at 4 meters), and getting at the hairy edge of a ported setup.
The large horns seem like the only thing that give me enough headroom, and as long as I can blend them into the decor as a windowseat I see no disadvantage to the large amount of space they would take up.
That's exactly the horn I was thinking about!!!
Now I just need to find a capable driver that produces a flat frequency response they make today, and learn how to downsize Volvo's design to fit my space requirements.
Very good to know I have no problem with a high pass filter Most likely with all the windows I'd be losing a lot of the ultralow end anyways
post #38 of 144
Another horn built with the Dayton drivers. In various sizes including the above mentioned lopro. http://www.billfitzmaurice.com/THT.html
post #39 of 144
Here is an idea....I see you have vaulted ceilings. Why not fly a big ass bass horn, or two, from the ceiling and paint them the ceiling color to not be conspicious. No floor print, but not the fight with physics.
P.S. if they are truly flying, I'd opt for a PP horn (or tapped horn) to offset the kinetics.
post #40 of 144
like this....
http://redspade-audio.blogspot.ca/20...-horns_02.html
Fly it 2-3 feet below the apex of your vaulted ceiling but well above the beams, and paint it your ceiling colour to be inconspicuous.
post #41 of 144
here is a front loaded horn sketch with the w15gti. it is purpose built per your size requirements. unfortunately, the limited space (height and depth) limit the horn size so only gives about 3db or a little more vs. a ported design. each one of these will do about 120db+ at 20hz, so two should be around 125db+ or so.
there would also be plenty of space in between them for your center.'
another thing ch, you probably aren't going to lose a full 6db per doubling of distance with subs in a room. the models are all for 2pi space (aka sitting outdoors in a field). the walls and ceiling enclose some of the pressure. this is called boundary gain. theoretically is is 6db each time that you cut the the space in half. so a corner loaded sub will have 12db over model for the back wall and the side wall in theory, but it typically isn't that high. all that glass is going to vibrate and turn the sound into heat...hehe which in maine might not be a bad thing...but no its not enough that you will ever feel it like you do with the sun coming through. :-)
the hornresp numbers aren't precise to the physical model, but the small amount by which they diverge shouldn't materially affect anything, unless i have made a major calculation error somewhere.
post #42 of 144
I agree with everyone that horns would provide the best output, but how do you hide them along the front wall and still install base trim while only having 19" to work with (I assume base trim is 5" height). Mathematically to me the only thing that can work is multiple 12's spanning the length of the front wall. 4 Alpine ported 12's tuned to 21hz would provide 124db+ across the board. That's also in a relatively small 4cu ft enclosure. If there is a horn design with a mouth and box shorter than 15" I would vote that route or the above based solely with room design in mind.
post #43 of 144
i didn't even think about venting the horn out of the top. that could be an idea too.
post #44 of 144
Good call! That would allow you to accommodate a 15" sub, and you could stain match wood vents (ie IB floor installs) to conceal the mouth and keep debris out.
post #45 of 144
Originally Posted by AudioJosh View Post
like this....
Love the thinking outside the box :-), but probably something like the T20 horn you mentioned above or LTD’s design below... not dangling from the ceiling! Where these will more or less be built into the structure of the house is the dual opposed really that helpful/that necessary? Seems it would be much harder to fit my narrow footprint.
LTD02!!! Love the Limey model! Thank you so much for putting the time into designing something like this. I really appreciate it! What program/method do you use to fold the horn anyways?
Could you either touch on or point me somewhere that explains the pros/cons of Front Loaded vs. Tapped horns? Looking at the FLH and TH designs I wonder if it is easier to get a low tuned/little bit more gain on a single sheet of MDF with a TH because you're not sacrificing physical space to the sealed volume behind the FLH. I've tried modeling several drivers with the TH, but have found nothing flat as the model you provided or that Volvo's design achieves with a no longer manufactured Eminence driver.
Maybe I'm thinking about the multiple sealed across the front in the wrong way, but how would they be easier to hide then the mouth of a horn?
More or less what I have floating through my mind is the subwoofer/mouth of the horn orientated vertical closest to the corner for each side. The baseboard/window trim would then go on after the box was built so it's dimension should place no variance in what size driver I use. I'll draw a picture later tonight hopefully.
Thanks all and happy Easter!
post #46 of 144
"LTD02!!! Love the Limey model! Thank you so much for putting the time into designing something like this. I really appreciate it!"
no problem. once you spend all the time to learn how to design and fold a horn, it doesn't take very long to cook something up. it can also become a little challenge to see what can be done/what is possible.
"What program/method do you use to fold the horn anyways?"
hornresp is the program that most everyone uses to design the horn in order to see how it will perform. if you know that you have 20 cubic feet per horn to work with, you design a 20 cubic foot horn as a start. from there, i use a little bit of intuition and mock up in microsoft word of all things and perform the calculations manually in excel. it's just geometry to translate the hornresp model into physical dimensions. my problem is that all my intuition is in inches and feet and hornresp is in cm and cm^2, so i spend half my time converting back and forth between units! it is a little bit of an iterative approach between the hornresp specs and the physical model until they are in harmony with the objectives and constraints of the plan.
others have spreadsheets that will calculate everything, but i haven't taken the time to learn them.
"Could you either touch on or point me somewhere that explains the pros/cons of Front Loaded vs. Tapped horns?"
i looked around quite a bit on that one and there isn't a strong consensus one way or another. there are people with both designs that report that they are better, cleaner, or whater, than the other. tapped horns are tricky because they tend to have more resonances and frequency suckouts to deal with. that said, they tend to do a little better on the low end for sensitivity. front loaded horns tend to have a much cleaner frequency response toward the top end. so there are advantages to each. it seems that tapped horns work a little better with stronger motored drivers, while front loaded horns seem to have a little more flexibility.
"Looking at the FLH and TH designs I wonder if it is easier to get a low tuned/little bit more gain on a single sheet of MDF with a TH because you're not sacrificing physical space to the sealed volume behind the FLH."
that is probably right in theory, but other aspects are more important.
"I've tried modeling several drivers with the TH, but have found nothing flat as the model you provided or that Volvo's design achieves with a no longer manufactured Eminence driver."
you have to be really careful when comparing horn designs for 'flatness' and sensitivity. if you model in something less than 2 pi space, the response will appear flatter than in 2 pi space. volvo's model is in 1 pi space. that also makes the spl higher than a 2pi space model.
then you have sensitivity. i always use 1w1m in model, while many others use 2.83v, which if your driver has something other than exactly 8 ohms resistance, will generate more power, so it is not a fair comparison. volvo used 2.83 volts and has a driver with an re of 5.27, so he is modelling 1.5 watts.
finding a flat response is a lot of trial and error with different drivers. i can sometimes get a sense for a driver that may work in a particular design, but sometimes i can be surprised, but that may just be me.
volvo has one mistake in that his s1->s2 length is 1cm. s2 is area in front of the center of the cone, so s1->s2 lenth can't be less than 1/2 the diameter of the driver. shortening up that length will make the response appear flatter. i'm not taking shots at volvo's design, just pointing some things out to look for in any design.
the flatness of the frequency response in what i posted was also "cheating" because i clipped off only up to 200hz and then scrunched it down to fit on the page. the peaks and dips appear much greater on my screen. in practice the peaks and dips won't be as bad as in the hornresp model. what the room does to your frequency response will almost always dominate.
some people suggest using "par" for the flaring, but in this case the difference is a db here and a db there. not practically significant.
i'm pretty sure a few folks put together a quick tutorial for what each s1 s2 s3 et al are in hornresp. if you search around, you can probably find it or ask lilmike.
bracing is also required. something like in this picture will work fine.
http://imageshack.us/photo/my-images...aklz7.gif/sr=1
one brace every 16 inches or so should help keep the cabinet from resonating too badly.
post #47 of 144
I'll be the first to admit my horn knowledge is limited, but in my head my concern is the mouth of the horn would be the same width of the driver at least, and if you front fire using a 15" driver that would leave you with 4" clearance for casing and trim (which is likely not adequate for front firing without notching out the trim/casing). Again since my horn knowledge is fairly limited I could be missing something about driver/mouth size. From a design and output stance I think LTD is onto something by up firing the mouth and corner loading.
post #48 of 144
Now what to do… Sealed, sealed, sealed or a couple smartly placed horns.
I've got 23’ width x 19" height x 18.5" depth. Somewhere in the center I'd like to integrate a B & W HTM Matrix Series center.
I'm plenty open to designing something of my own, but have a huge amount to learn… HELP! :-)
In that space volume and placement what I would do is...
Start with 6 Dayton 15 HF's in 3 dual-opposed boxes of 19x18.5 x22ish with 3 Behringer iNuke 3000DSP. Or even just two and then as your budget expands you could add as many as 10 boxes under the window because you have the space to grow. For a total of 17,600watts into 20 Dayton 15's @ 4ohm.
That really is the easy-button solution.
Finding enough power outlets will be your next challenge.
post #49 of 144
Obviously the LMS Ultra is going to be the best power handling wise, and it's
musicality is on par with the B&W 802 Diamond. It distorts less than just about any other subwoofer on the planet.
But as soon as you say the word 5400, you are instantly looking at $3000+ because you are probably going to need two for a room that size minimum.
You COULD fit it within those dimensions but you would have to mount it vertically like I do but 6 inches lower to the ground, with a box that is wider to compensate the decreased volume of the height and depth restrictions.
My room is just over half the size and volume yours is and my LMS does alright in it, I was able to crack the drywall as you can hear at the end of the video when it is vibrating against the joists.
post #50 of 144
See replies in bold
Horns all the way!
Looking at your first picture, I'd put the centre just in front of the screen, under it. Tricky situation - can you raise your screen a little? Enough to put the centre roughly the same height as the mains, if not slightly lower?
You could fit 3 modules that are each only just a touch smaller than my T20. 18.5" x 19" x 1/3 of the 23 ft. A rough first guess would be one 15" sub driver in each. You would probably get about 120 db max SPL from a single tapped horn, 2 yields 126 and 3 about 129 db from around 20 Hz up. Rough guess. This is at 1m, less in your listening position. Allowing for the bass running at a higher level then you probably have good match. It's not nearly as crazy as it sounds.
Lower distortion, more output. If cost were no object, then the best option of all would likely be a large number of infinite baffle sub drivers with a lot of power. However, with more realistic limits, a custom horn is hard to beat. The main downside apart from size is limited bandwidth.
Ok decided to come up with something.
3 of these should fit:
Halfspace sim with 500w, Dayton RS15" driver, 15mm excursion:
http://redspade-audio.blogspot.com.a...rn-design.html
Simple to build.
The advantage of dual opposed is vibration reduction. Might help if you end up with pot plants or things on top that might rattle.
post #51 of 144
Wow… Pretty pathetic it took me a few days to get back to my own post, and much of the reasoning behind that is I've been up to my eyeballs testing out different horn designs, almost like a crack addict looking for his next fix, with horn response open on one screen, Microsoft Excel on another, and Google sketch up on another.
I think what I've come up with so far from a construction/I actually need to be able to build this thing standpoint is to build two of whatever horns will fit in a 98" Width x 19" Height x 18.5" Depth volume and let the tuning end up where ends up. Theoretically this is around a 475 cm path, so 18 Hz should be possible, but if it's a little higher than that, well, it's more important that these things are actually buildable!
I like the tapped horn idea because construction should be the easiest… more or less a box with a diagonal setting the horn, and driver access will hopefully be possible through the mouth. If I can model a FLH with better performance that will fit in my 8’ wide dimension then I'll go that route.
Two JBL W12GTis seem to do pretty well in this orientation. 123 dB+ from 20-60 hz in 2 pi space. Sure would be nice if I could build a horn with similar output/characteristics with just a single 12" or 15", but this performance doesn't seem like anything to be laughed at unless I screwed up somewhere in the math.
Anyways this is turning into a really fun project and I appreciate all the help/thoughts!
Definitely a great and very valid thought… I'll either be leaving the trim off all together where the mouth is, firing up, or at the very least accommodating the area of the mouth to make up for the trim so that it is the proper square centimeters.
Simple to build.
Paul!
You, LTD, lilmike, and a few others have really sold me on the whole thought of a couple horns! I just love the science behind it, the dynamics, reduced distortion, and just doing more with less. Seems like a beautiful thing!
At that, I think two is plenty :-) yes three is more an obviously better, but to is enough to fulfill my objectives. Now what can we do to bring be corner frequency of your Dayton horn down a few clicks… Maybe to at 20 Hz. If we can get that figured out I'm ready to start building!
And the center channel will be moving down… That was a stupid idea I had to get it up off the floor. Sounds like crap and it really screws up the dialogue. I won't be able to get it to the height of the midrange/tweeters of my mains, but it'll at least be even with the window sill. Just waiting now for the weather to warm up so that we can pop awesome siding and move the wire around.
post #52 of 144
Those LMSs are crazy Just freaking CRAZY! I'm just so amazed by what they can do in such a small enclosure!!! Really seems like just the best cost is no option solution out there, but like you said $3000 for two, and then I'd have to have my electrician run a 240V circuit back to the media room because there is no way my two dedicated circuits could run two of those along with all my other home theater stuff.
I mean I drool looking at what you subs can do they are really such a beautiful thing, but at the same point I can't get past the fact that one cost as much as six Dayton 15s, and would put out far less output across the board. If space was such a premium I'd definitely consider the trade-off, but I have a few places in my room where I can spare a few cubic feet.
Love the video!
But for some reason I just can't get enough of these horns!
post #53 of 144
There is always a trade off. I tried a lower tuned version, allowing for two of them. Smoother response but 117 db max SPL for one, 123 db for two, -3 dB @ 17 Hz with 300w to each driver.
With the previous version, it can take more power (400w) and has slightly less extension (21 Hz) but 5 db more SPL at 25 Hz.
The little bit of extra extension is probably a lot less audible than twice as much oomph at 25 Hz, but the smoother curve of the bigger one looks better on paper. This is with the Dayton RS 15" driver.
The smaller one is much easier to lift and work on - it's a little bit smaller than my T20, which is light for a horn but certainly heavy enough! When it's heavy, it gets hard to lower things gently to the ground, they tend to land with a thunk! When installing my T20 it landed hard a few times, but I wasn't too concerned because it's an ugly beast under the floor that won't be seen. In your case, something prettier, so don't overlook this side of things.
post #54 of 144
Wow Pretty pathetic it took me a few days to get back to my own post, and much of the reasoning behind that is I've been up to my eyeballs testing out different horn designs, almost like a crack addict looking for his next fix
I'll just warn you now - there's no known cure. It's best to just surrender to the addiction.
post #55 of 144
Just finished assembling two THT-LP with RSS390's. Cabinets were built to the maximum 36" recommended width. I'm still dialing them in.
My room is a similar size with a 9ft ceiling, but fewer windows. They are being fed by two Bash 300S amps.
This is one of them in a vertical position....
Here's their currrent orientation. Final finish to be determined...
Rattles my deck outside.
post #56 of 144
Definitely agree that 5 db more at 25 Hz would be way more noticeable, but if I'm never going to be playing up in the mid-120s wouldn't the extra extension/smoother response be more noticeable since it would actually be there throughout the entire SPL range... Whether I'm just listening at reasonable levels cranking to reference.
What if I were to put a more capable driver into the lower tuned horn? Do you mind posting the hornresp files? I'd love to play around with a few different options/drivers.
Thanks! -Mike
You sure aren't kidding!
I thought about going that route too! What did you finish/build yours out of? They look beautiful! First impressions?
post #57 of 144
Thanks! -Mike
Assembled them out of the recommended 1/2" baltic birch plywood. I haven't seen a birch finish that I like so I have some rift-cut red oak veneer in waiting. Once I decide which orientation (horiz/vert) I'll give them a furniture-grade stain and topcoat. Probably black/brown dye stain mix, and satin polyurethane.
I'm still waiting on an OmniMic to mess around with response. The first one was amazing, but after adding the second...
My family room opens partially into the main level of the house, so effective volume is much larger. I'm glad I added the second THT.
THT and THTLP are both supposed to have the same performance. I went with LP's so I could max out on the dimensions and consequently, the low end extension, and still get them through the doorway. If you can get 36" cubes into your house, the THT's might be a better fit around your windows.
post #58 of 144
Alright guys, been away for a little while Life caught up with me What can I say!
But after lots of help back and forth from lilmike, and the help/designs from LTD, PaulSpencer, Oklahoma, and others, I think we've come up with a pretty awesome design with a minimum of compromises assuming one very important thing the T/S parameters of the Fi SSD15 are accurate!?!
What do you think of the Horn Response output below and the Fi SSD15 driver used in a tapped horn.
Shows a relatively flat 120+ db from 20-80 Hz with 1000 watts per horn in 2 pi space, with driver displacement below xmax throughout. With two corner loaded I should hopefully eq to 15-17 Hz at reference.
The design is a real easy single fold as shown below.
Any thoughts?!? Please tear this thing apart, and if the consensus is dang that'll work good Then I am ordering the drivers ASAP!!!
Thanks so much for the help and thoughts!
post #59 of 144
Think about how you will install the driver. Current design looks like it needs a hatch. You can use the mouth for that if you place it in the front.
Since the excursion climbs up just above 20 Hz, your only real way to get below 20 Hz is with room gain, if you have enough of it. This is where you think about the trade off between efficiency and extension.
post #60 of 144
I don't have anything constructive to add but I just wanted to say that your room is awesome. I wish I had a room that cool. Best of luck with your build.
