Originally Posted by
Chassmain
Thanks for all the input folks!
Always, even from the beginning, I have conceded to the fact that I won't be driving these with my consumer grade home theater amps. Just was so excited to get them bumping that I used one with disastrous effects. Whatever, the company is coming good on the amp, and over the weekend I tore one of the plate amps out of my 10-year-old piece of junk Acoustic Research subwoofer and can't get over the results.
I AM SIMPLY BLOWN AWAY!
Glad to hear. Told ya you'd have to experience it.
Chassmain
The bass is unlike anything I've ever heard in my room or any home/theater setting. It's just freaking incredible! The easiest way to explain it is it almost feels more like something I'd expect more from a live concert then in my living room. The impact, dynamics, volume It literally shakes the walls! And this running only one of them with a piece of crap 200 W amp at less than half gain with nothing more than a built-in 20 Hz high pass filter. I can't imagine what these will be like when I hook them up to a real amp.
Add about 13 dBs. Simply put, more than twice what you have now. Should make things interesting....
Chassmain
Now what should that amp be?
I know everyone is right in love with the Behringer ep2500/4000, but I must admit the simplicity of having amp/DSP all-in-one with something like their iNUKEDSP 3000 is pretty hard to resist. I have half a mind to sell my never used balanced miniDSP and just go for it with one of the iNUKE amps. Anyone want to buy my miniDSP?
Any reason why not to get a iNuke?
The 3K DSP will be plenty of amp for you. I have one, I have wrung it out testing a CVX (8 ohm load with the amp bridged), and I found it to deliver until I pushed the amp and driver to their respective limits. I'm not 100% sure that the limits I found are only the amp to be honest. I have measured the amp's response, it is basically flat until 10 Hz (with a low output level - not sure about war volume yet, need to make that 4 KW dummy load).
The limits I found won't really apply to you, that sub was tuned lower than yours. Also - the limits were evident with sine waves, but not so much with music or program material. I'll be using my iNuke 3K DSP with my CVX subs once they're built, as I'm currently limited to a tune above 20 Hz due to space constraints. During testing, we ran Todd's subs with both. The EP2500/4000 seems to deliver a bit more down low, but above 20 Hz, the iNuke is definitely in the race. If you don't need EQ or highpass below 20 Hz, I think that the iNuke 3000DSP is an excellent choice.
