AVS › AVS Forum › Audio › Home Theater In A Box › $450 budget - which small room HTIB with wireless network?
post #1 of 5
I have a small room but want to install a HTIB solution which has the following requirements:
1. Blu Ray (3D not required)
2. Wireless Internet connectivity included for Netflix apps etc.
3. 2 HDMI inputs
Also, I have noticed some complaints about sony systems with Audio/Vid sync and want to avoid that sort of thing.
I want to purchase quickly .. Wife out of town till Sunday night, so now is my opportunity
Thanks for your help
Burning-Rope
(Not a fetish ... A Genesis Song!!!)
post #2 of 5
$450 for a blu ray player and a HTIB is a stretch for quality. I'd get the onkyo HTIB from somewhere like newegg for $399. I put one in a friends house and it sounded good for the money. Then get a good blu ray player if needs be at a later date.
post #3 of 5
Go seperates, you get more flexibility that way.
Monoprice 5.1 speaker system, $84.
http://www.monoprice.com/products/pr...mat=4#feedback
CNET Review:
http://reviews.cnet.com/surround-spe...?tag=mncol;txt
Pioneer VSX-821 receiver, $159 shipped with promo code EMCNFJH22
http://www.newegg.com/Product/Produc...82E16882117397
Sony BDP-S590 3D Blu Ray player with Wi-Fi and Netflix streaming, $139
http://www.amazon.com/Sony-BDP-S590-...pr_product_top
12 ft Subwoofer cable and Y cable for sub with dual inputs, under $7.50 total
Three 6-foot HDMI cables, $3.50 each
100ft Speaker wire, 16ga, $19
All under $450.
post #4 of 5
CNET Review:
All under $450.
Thanks for putting this together. I'm looking for something similar, and don't know a ton about sound.
I have a small budget and am looking into filling up my decent sized bedroom with pretty good sound. This is my first attempt down this line -- have just been using a nice 2.1 set of computer speakers.
I want to have a receiver go out to my projector and input my laptop via HDMI into the receiver. I may add a used PS3 down the road so I can watch BluRay and NetFlix without tying up my laptop -- I figure that is the cheapest solution to upgrade the input device.
The speakers seem pretty good, and unless I find a real steal of a used one on craigslist, perhaps the best deal out there?
Can I find a less expensive receiver for my needs of maybe only two HDMI in and one out, or is this about it? I figure anything used that's older than the last couple years may have issues with earlier versions of HDMI, so new is the best route here?
post #5 of 5
$159 is pretty darn cheap for a current HDMI receiver that passes 3D video.
  Back to Forum: Home Theater In A Box
