Posted this over in the spectracal forum but maybe of interest to others that don't frequent that site and/or have D3 and i1pro. Not sure if you get the tripod mount with the D3, I don't think it comes with one.
If you want to profile and adhere to keeping both meters with the same field of view this is a fast, 2 hole, one bolt modification if you have the tripod mount for the i1pro and the C6. It may not work to well with Front projection if your meters will be in the light path (you will need to tilt up) but for my purpose (HP screen, meters over the projector) should be fine (will be using it tonight)
If anyone wants to try this and needs measurements or instructions, just ask but it is really simple
You will need:
Drill or Drill press
7/16 bit
1/4 bit
center punch and hammer
1/4" bolt or screw
Offset distance is 17cm
You will need:
7/16 bit
1/4 bit
1/4" bolt or screw
