AVS › AVS Forum › Audio › Soundbars › TVee Model 30
TVee Model 30
post #1 of 3
Hello all...I am having issues with Boston acoustics TVee 30 and wanted to see if anyone else had similar issues and/or input.
Setup info: Using digital out from a sharp lc60le633u into the TVee 30. When using the digital optical input, the system will only stay on for ~60 seconds and then put itself in standby mode. I can manually power up the system and it will always only remain on for 60 seconds and then automatically power down.
I have used the 3.5mm side input successfully, as well as, the bluetooth input and do not experience the automatic standby after 60 seconds. Any help would be greatly appreciated.
post #2 of 3
If your soundbar is under factory warranty, did you happen to contact the BA support?
post #3 of 3
I assume you are getting sound while using the optical out for those few seconds? I know on my Sony LCD tv I have to have a digital source (ie HD TV or playing blue ray) to get sound. As I do not have HD tv i have my TVee 30 hooked up using coax cables. My Blue ray is using fiber optics and my Ipod touch is used with bluetooth.
  Back to Forum: Soundbars
