Probably best to continue this discussion in the JP1 forums where other experts and the authors of the software can weigh in. But I'll go ahead and answer what I can.
I actually picked the Philips HTS3544 which I thought was a better match. I opened it in KM and changed it to your remote model, converted it to an RM file and posted it below. Copy that text into a new file called "Philips HTS3544.rmdu", and open that in RM.
1) Don't know. Worked ok for me. But you should be using RM anyway. KM is an older tool that has essentially been superseded by RM.
2) Could be something wrong with the file. Need expert help there.
3) Those come from many sources like posts from others at remote central, learns, similar upgrade files, conversions from pronto hex, manufacturer's technical documents, etc. Our software (RM, IRScope, etc.) decodes your learns and converts them to EFCs. That's how you can make your own device upgrades.
4) Yes. Most, if not all of those probably exist in our file section. If not, just post a request and one of our members will make an upgrade for you. Or just make your own by learning if you still have the original remote. In your case, I'd start with our Scientific Atlanta 8240, Sony BDP-S580 (all sony blu-ray codes are the same), and Panasonic TC-P65S2.
Big picture, this is how it goes usually goes:
- Search our file section for your devices or a close match
- Open each in RM, pick the remote is was made for in the drop down, then change it to your model. When you get a cable, RM will actually identify your remote, so you don't have to guess. Drag and drop functions to the the buttons of your choice.
- Add each device upgrade to your remote in RMIR and upload to your remote.
If you can't find a device upgrade, ask or make your own from learning. That's how the thousands of upgrades in our file section got there.
Warning: Spoiler! (Click to show)Spoiler
Code:
Description=Philips HTS3544 Home Theater
Remote.name=Atlas OCAP URC-1056 JP1.3 (Black)
Remote.signature=30333033
DeviceType=DVD
DeviceIndex=2
SetupCode=1025
Protocol=01 84
Protocol.name=RC5/6 Combo
Protocol.variantName=2
ProtocolParms=4 16 21
FixedData=95 30 55 65 56 55 56 66
Notes=
Function.0.name=0
Function.0.hex=0A 01
Function.1.name=1
Function.1.hex=01 01
Function.2.name=2
Function.2.hex=02 01
Function.3.name=3
Function.3.hex=03 01
Function.4.name=4
Function.4.hex=04 01
Function.5.name=5
Function.5.hex=05 01
Function.6.name=6
Function.6.hex=06 01
Function.7.name=7
Function.7.hex=07 01
Function.8.name=8
Function.8.hex=08 01
Function.9.name=9
Function.9.hex=09 01
Function.10.name=vol up
Function.10.hex=10 03
Function.11.name=vol down
Function.11.hex=11 03
Function.12.name=mute
Function.12.hex=0D 03
Function.13.name=Display
Function.13.hex=0F 01
Function.14.name=sound
Function.14.hex=51 03
Function.15.name=power
Function.15.hex=C7 01
Function.16.name=audio sync
Function.16.hex=B9 03
Function.17.name=subtitle
Function.17.hex=4B 01
Function.18.name=disc menu
Function.18.hex=D1 01
Function.19.name=Title
Function.19.hex=83 01
Function.20.name=up arrow
Function.20.hex=58 01
Function.21.name=down arrow
Function.21.hex=59 01
Function.22.name=left arrow
Function.22.hex=5A 01
Function.23.name=right arrow
Function.23.hex=5B 01
Function.24.name=ok/select
Function.24.hex=5C 01
Function.25.name=zoom
Function.25.hex=F7 01
Function.26.name=repeat
Function.26.hex=1D 01
Function.27.name=play
Function.27.hex=2C 01
Function.28.name=rewind
Function.28.hex=21 01
Function.29.name=fast fwd
Function.29.hex=20 01
Function.30.name=stop
Function.30.hex=31 01
Function.31.name=surround
Function.31.hex=52 03
Function.32.name=USB/Disc
Function.32.hex=3F 01
Function.33.name=Radio
Function.33.hex=40 01
Function.34.name=TV
Function.34.hex=41 01
Function.35.name=Open/Close
Function.35.hex=42 01
Function.36.name=Aux/DI
Function.36.hex=3F 05
Function.37.name=MP3/Line-in
Function.37.hex=38 05
Function.38.name=Dock
Function.38.hex=45 01
Button.1f=0|null|null
Button.15=1|null|null
Button.16=2|null|null
Button.17=3|null|null
Button.19=4|null|null
Button.1a=5|null|null
Button.1b=6|null|null
Button.1c=7|null|null
Button.1d=8|null|null
Button.1e=9|null|null
Button.4=vol up|null|null
Button.5=vol down|null|null
Button.33=mute|null|null
Button.3=power|null|null
Button.29=up arrow|null|null
Button.2a=down arrow|null|null
Button.2b=left arrow|null|null
Button.2c=right arrow|null|null
Button.13=Display|null|null
Button.c=play|null|null
Button.b=rewind|null|null
Button.d=fast fwd|null|null
Button.e=stop|null|null
Button.25=surround|null|null
Button.1=TV|null|null
