AVS › AVS Forum › Audio › 2 Channel Audio › HD Tracks quality? Please share your experience about this download service
HD Tracks quality? Please share your experience about this download service - Page 4
post #91 of 99
back from the dead ....
quality varies as has been said...
probably cheaper than the sacd and certainly easier to find these days
only place for dinosaur rock
post #92 of 99
I've ripped some of my favorite cds to (with Media Monkey) flac and I've also downloaded a couple of HD Tracks' albums. The HD Tracks albums, The Stones' "Between The Buttons" and Fleetwood Mac's "Tango In The Night" sounded significantly better than any of the cds I've ripped. I'm guessing that your mileage will vary. Don't forget that the recording quality of the older albums varies quite a bit and you just can't make a silk purse out of a pig ear.
"Tango In The Night" sounded so much better though, it must have been (at least) remixed. I haven't been able to find much information on the history of these older recordings. I'm think that a lot of the original cds from the 80s and 90s were mixed very poorly so anything remixed or remastered in the past 10 years is going to sound better than a cd that's 15+ years old.
post #93 of 99
Skipping issues with Tea for the Tillerman, Goodbye Yellow Brick Road and Glad Rag Doll
Has anybody purchased these albums and if so do you have any issues.
Below is the email I sent to HDtracks. Initially, kind of got the brush off, as obviously someone did not think to read my issues right thru. After a second reply, they resent the 3 albums . i deleted the original and proceeded to download again. No issues with the 2nd download. But the issues are still there. Affecting different tracks slightly. The sound itself is great and compares to the other hi-def records I own, however, there is definite skips type of issues. The same skips occur at the same spot no matter how many times i play them. The Diana Krall is the worst by far with issues on most tracks. These are my first purchases with the upgraded HD-Downloader.
Music is on a Mac supported WD drive. The only thing on the mini is OSX Mt Lion and Amarra Hi-Fi (on SSD). Hard wired with cat6 for internet.
HDtracks response to my third inquiry after the second install was to contact Amarra. I would think that if it was an Amarra issue, it would affect my other albums. Why only these 3? and not the sampler that was picked up at the same time with the same hook up etc. All my other ripped music at 44.1, 48, 96 an 192 plays fine.
Any suggestions are most welcome, as I'm totally frustrated.
Thank you.
"Hello,
I purchased the attached as well as the 2013 Sampler. On initial download it failed, but I succeeded the following day.
Now that the holidays are over, I got to actually sit down and listen. The sampler comes out perfect with no issues. On this order however I have quite a few hiccups. Part of the music goes missing for a partial second. It almost sounds like a skip. This is repeatable every time I played it.
This happens on the following albums:
Tea For the Tillerman
#4 Sad Lisa - an additional note at the end of the song
#9 On the road to find out - 3:40 to 3:50 - skips + extra note at end
# 10 Father & Son -there is voice saying "welcome" near the end that does not belong in this song
#11 - when song 10 was complete, it did not move to 11. If 11 was selected, than it would play.
#1 Funeral for a friend - and additional note at the end
# 5 - Song has no title - 1:07 sounds like Diana Krall voice for a split second
#11 - plays fine, but a loud beep sound at the end
Diana Krall - Glad Rag Doll
ONLY songs # 12, 14 & 15 play without any issues.
There are considerable skips especially on the first half of the album. With multiple issues within the same song.
I have double checked my equipment and went back and played every high def song I have to make sure there are no universal issues. Your 2013 Sampler, Audiogon 2012 Sampler, Dusty Springfield, Fleetwood Mac and War which I purchased from you previously all work perfectly.
Any ideas on what's going on or how I can fix this will be greatly appreciated. "
post #94 of 99
I have both goodbye yellow brick road and tea for the tillerman and have NO problems with either
post #95 of 99
Tea For the Tillermam; no issues....
post #96 of 99
If I really really care about hi-fi, I will spend a paycheck and get a nice turntable and put some of my records on.
I just came across Mastered For iTunes Black Sabbath albums that are supposed to sound better than the currently-available CD's. Wonder if those masters will go on HDTracks at all.
A crappy master is going to sound crappy regardless of format.
Placebo effect is not to be underestimated. Plus you have to wonder if what you're hearing is all coming from the same master.
Edited by hogger129 - 1/18/14 at 3:58pm
post #97 of 99
This statement times a million. It can't be overstated. I'd take a well mastered album on CD than a poorly mastered (or from a low generation master tape that I suspect those SHM-SACD's are mastered from) album on HD Tracks, or SACD, any day of the week.
post #98 of 99
I would say it's a case-by-case basis whether an album was remixed for cd to begin with. Not every one has been.
What evidence do you have of this? Are you also aware of the (sad) recent trend of the overuse of compression on music?
post #99 of 99
I would have to VERY much disagree with you. In fact, I'm finding a lot of remasters done in the last ten years that sound worse than a remaster done before that, or the original release.
Then again, hey, whatever. All that should matter is you get enjoyment out of your music. There's the whole "holier than thou" crowd out there who can't get enjoyment out of anything but vinyl too.
Edited by hogger129 - 1/18/14 at 5:23pm
