Originally Posted by Dennis Erskine
Hi Randy:
Identical subs at the same SPL and Phase act approximately as would a single sub at the mid-point between the subs. Let's assume you have two subs. If you raise the SPL on one of the subs, that would move the "mid-point" away from the louder of the two subs. Same is true with 4 to 500 subwoofers.
Matched identically is always the starting point in the calibration process. You can then measure the response at each seating location and develop your EQ strategy from that point forward.
Hi Randy:
Thanks Dennis. Appreciate the info.
