AVS › AVS Forum › Audio › Speakers › Sub $100 bookshelves for parents
post #1 of 39
My parents just got a new plasma for their rec room. They want to get a pair of bookshelf speakers to use in place of the tinny built ins. I try to push them to spend a bit more but they are firm at $100. I am totally out of the loop in speakers right now and haven't even looked at anything since I bought my B&W 602s about 8 years ago so I thought I would try to get some opinions on here where to start. Thanks.
post #2 of 39
Do they have a receiver?
RBH speakers
http://www.ebay.com/itm/RBH-MODEL-AC...item3a72ee2700
http://www.rbhsound.com/ac51.php
Bookshelf Speaker
Frequency Response:
60Hz-20kHz (±3dB)
Sensitivity:
86dB (2.83V @ 1 Meter)
Recommended Power:
100 Watts
Drive Units
(1) 5-1/4" (133mm) Polypropylene Woofer
(1) 1" (25mm) Fabric Dome Tweeter
post #3 of 39
Do they have some way to power the speakers?
post #4 of 39
I know you did not mention a sub. But I put together a 2.1 system for 100 bucks. It sounds really good. It is Dayton Audio 6.5" bookshelf with their 8" sub. I got the bookshelfs for 30 bucks. They were on sale. Last I checked they were 40 bucks. Hard to beat for that price.
post #5 of 39
Those Daytons arent bad for the money at all. Another choice are the Pioneers:
http://www.newegg.com/Product/Produc...82E16882117405
They are currently on sale for $49 shipped!
post #6 of 39
The Dayton and Pioneer suggestions sound good. Depending what your parents expect for ther $100...and like has been asked, do they have a receiver/amp to power them? Do they want self powered speakers?
post #7 of 39
Yes they have an older 2 channel receiver to power them. I was looking at the pioneers but they would have to set them on their side to fit on their shelf.
post #8 of 39
you can use this little lepai amp with those pioneer speakers above
http://www.amazon.com/gp/product/B00...A2PCCTD0H7OEMJ
are your parents insistant on using that stereo? if not, the pioneers and amp would be $75 total and also this way the speakers would fit on the shelf
post #9 of 39
They are not set on the receiver. Only criteria is they need to be able to control it with their Dish Network remote. They would probably prefer that little thing over the big old receiver if the remote would work.
post #10 of 39
I've heard awesome things about those Daytons. They're cheap as heck but people say they sound like speakers selling for much more. I'm thinking of buying a pair just to hear them.
Dayton Audio B652
http://www.parts-express.com/pe/show...ource=googleps
Above isn't necessarily the best deal but it's the speakers I was talking about, and a deal with them and an amp wouldn't be bad at all.
post #11 of 39
Oh never mind on the receiver. They do want to use what they have. They need the tuner and the phono input that it has.
post #12 of 39
Instead of bookshelves, why not go with a decent soundbar? They range anywhere from $98 for something like the Vizio VSB2xx series to more than $1,000.00 for higher end ones.
post #13 of 39
I thought of a soundbar but they want the fm tuner and phono input. Not sure if that's easily doable without the receiver.
post #14 of 39
There are small amps, but for $100 you are really looking at sub-par equipment that is not going to last real long, along with sounding like two tin cans. If it was me, I would keep it separate. A system for them to listen to FM radio & their turntable, and the soundbar for the tv only. That is how I have my living room set up. A 2 channel receiver with bookshelves on stands, and the soundbar for watching tv and bd playback.
post #15 of 39
Thing is they have the receiver and the turntable already just minus speakers. I had thought a pair of 100$ speakers using their existing receiver would be as good or better than a $100 sound bar for TV and movies plus be able to use the FM or turntable. They are not looking for audiophile stuff. I just want to make sure whatever they do is an upgrade from the built in speakers. Plus I think they want a path to upgrade to a 5.1 setup in the future.
post #16 of 39
The problem with using the bookshelf speakers, that unless they are near the tv, when you are watching tv, the sound is going to be off, and actually make it sound worst. You can still go with both options, and it would not be high end, but they would probably appreciate the sound quality better.
As for going back to your original question, and moving up to 5.1, you are going to find that speakers sound differently to everyone, and getting decent bookshelves for under a $100.00 can be done, but I would have the parents make the final decision, than getting something that they do not like.
As for the current equipment and using a soundbar for the output, you would use a rca to rca from the Tape out to the sound bar input, and they would be able to use the sound bar for listening to the fm radio or turntable. But keep in mind, that you parents are going to have the last say, and what ever you like, you always know that they will not like, or just don't care in the end.
post #17 of 39
I prefer the bookshelf option over a cheap $100 SoundBar. I would
still try to make something like, the RBH or Pioneer speakers work.
I have listened to the Dayton cousin speakers, they would at least
be better than the TV speakers. Good Luck!
post #18 of 39
You have exactly the right idea. And the receiver is a better option than that little underpowered amp.
But rather than making people guess, maybe you could let us know what the space constraints are.
BTW, speakers on their side are fine.
$100 is enough.
Those Pioneers are probably the best bet for sound quality for the money. Or one of the many Polk sales at NewEgg.
Here's a review of the Dayton B652. It's $45 shipped at Amazon, lots of user comments at both sites.
If those are too big, these Sonys are alright.
post #19 of 39
post #20 of 39
They have 12" high by 14" wide in their shelf. They plan to put them just below and to either side of the tv. I think I am planning to suggest the Pioneers. I am trying to convince them to go with the fs51 and set them to either side of the tv stand because it's a pretty good size room. In the end I think they will probably go with the bs21s.
post #21 of 39
Is there any way of posting a picture with their permission of the area that we are talking about, that the speakers will be placed into? That would give an idea of what you are dealing with. That along with a floor plan of how far they are going to be sitting from the tv, along with the spec's on the receiver that they are going to be using with these speakers, until they decide to upgrade.
post #22 of 39
Any particular size woofer they are looking for in a bookshelf speaker?
post #23 of 39
The room is about 18 x 24. That is about 10 feet on center from the right side of the long wall. On the left side if the room facing the tv is a bar. The main listening position is directly across the room from the tv, so about 15 feet. They want the speakers on the left and right shelf just below the tv. The shelf space is 12". Im still trying to lead them to the fs51s because i think the speakers will be to low and almost hidden on tgat shelf, but so far they are sticking to using the shelf. The receiver is a Pioneer VSX 305. I think it's 60w per channel.
post #24 of 39
Your picture of the room isn't working.
post #25 of 39
That Dayton speaker may not fit in the 12'' high shelf your parents have. The height measurement on the Dayton is 11-13/16''. These bookshelf speakers will fit though.http://www.parts-express.com/pe/show...number=304-002
I own several pairs of these speakers and they're impressive speakers. They used to cost under $100 but the price has went up a little. They're still only $30 over budget. They're even rated well in this bookshelf speaker review. http://bookshelf-speakers-review.toptenreviews.com/
post #26 of 39
Fixed
post #27 of 39
Just get them this set up since the placing and budget are not any where near ideal. You may have to kick in a little cash if the are hard set on their 100 budget, but hey it's for mom and dad and they deserve it.
http://www.parts-express.com/pe/show...number=300-652
http://www.parts-express.com/pe/show...number=300-631
Good luck!!
post #28 of 39
The Sony SS-B1000 speakers are $49/pair on Amazon.
Those are probably the best-sounding speakers you are likely to find in your size and price range.
They should be the perfect solution. They are 10.7" tall.
post #29 of 39
imo iwould talk mom and dad on a pair of tower speakers like the pioneer sp-fs51's or a pair of sony ss-f6000 (both $129) .ijust can't see getting a good soundstage with speakers on the shelves that close together and the drivers below ear level. this way you can place towers a bit apart from tv to get better soundstage and eliminate buying stands for bookshelves and adding more bass for that size room just my 2 cents
post #30 of 39
May be hard to convince your parents (mom particularly?) that while they may like the looks of the speakers on the shelves, they won't sound the best there, but they may not care. They still have VHS? Maybe the angle should be: Where would they put the phone? Tapes? The suggested towers do look fairly nice, maybe you need to show them...or simply buy them the good stuff as a present.
  Back to Forum: Speakers
