AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Looking for a 32' LED with Headphone jack
post #1 of 6
Hello,
I'm looking for a 32 ' LED TV with headphone jack for my bedroom. The only one I could find is the LG 32LV2500. Is it a good choice?
Other recommandations?
Thank you!!!
post #2 of 6
Anything with analog audio out will work...then just get an, RCA to stereo mini, adapter.
post #3 of 6
Electrically, I don't think that is correct. RCA output will have different impedance output than headphone jack output. And in most cases, heaphone output volume is controlable via TV where RCA output is not (unless your Tv have Variable Audio Output option).
post #4 of 6
I've done it many many times and never had an issue...but you will want the ability to control volume be it with VAO or the headphones.
post #5 of 6
That only works if you can turn off the speakers on the TV so the sound only goes through the headphones. Otherwise you get sound out of both
post #6 of 6
