I convinced my wife that we could save some $$ by getting rid of our 2 setup top boxes by going with a tuner card connected to the HTPC. The one requirement was I needed to get WMC 7 working properly before we sent the boxes back!!
I am kinda torn between the HDHR prime and the Ceton inifiniTV card and could use some advice/opinions.
We have FIOS service with a QIP7232 2 (500gb?) HDDVR downstairs and a standard HD setup box upstairs. I do not have a xbox 360 yet, but have 2 PCs with Windows7 home. We have 2 TVs that are used and will probably add a third in the basement and I could see adding a 4th in the spare bedroom but that is not a requirement right now. We do not have ethernet run upstairs but I think that I can use one of these MoCA adapters
to get ethernet to the upstairs PC. We don't have a need to use a tuner for a moveable laptop or ipad.
Given that, what are your suggestions?
Also, I have a question about DVR capacity and drive connection. My FIOS DVD stays about 2/3's full and I believe it's a 500gb model, I guess that I should stick with a 500GB HDD for DVR in my HTPC? Should this DVR HDD be dedicated for ONLY DVR? I do have a 2TB drive that has plenty of space, I am just wondering if the DVR drive should be a separate physical drive.
