Originally Posted by artisanoo
interesting, so the final result may differ for example, when adding lets say X oz. of some NG, vs adding 2X of a 'half as dark' NG.
is that the reason the SF colorant is so dark, so you can add less of it as a percent of the reflective elements? i.e. less 'dark color' is potentially better than 'more light color' tinting?
Yes. Reflectivity maintained relates to gain at whatever level/shade of Gray.
didnt think about the gold, thats a good point - though the gold would add in some more reflective components. assuming this is not a huge issue..?
Actually, the use of a metallic is designed to maintain reflectivity while adding an additional primary to correct a push. No metallics, and the added material also becomes a "mask"
as far as the amount, i get that it is subjective, so heres a more specific question - given the projector and the potential for brightness and FL's, what is the darkest you would recommend before its 'too dark'? i suppose we can talk in 'terms' of SF ratings (which we can translate based on what you said above about the 2:1 ratio of NG:SF colorant comparison). that way i would have at least an upper and lower boundary of where i should be playing as far as darkness levels.
SF 2.5 4.0
heres a practical question - aside from the potential reflection problems (lining up of mica, etc), would rolling/brushing a small sample of a mix give a decent approximation of what the final screen would look like? if so, might it be a good idea to make a few small samples with just a small of paint to hold in front of the PJ to decide what level of darkness/gold offset would work for me? i suppose samples can be sprayed too, but if i was experimenting with adding differing amounts of NG, the turnaround time would be a lot faster between tests if i didnt have to clean/prepare the gun each time.
Samples can be and usually are misleading unless substantial in size (2' x 3')
Personally speaking, your really not on such a knife-edge as far as it's being guesswork. Either of the suggested choices would do nicely. Everything is based upon need/future-proofing if desired, and work ethic. The suggestions come easily enough and you can bank on them if all the known criteria is provided.
If the SF Mix and Colorant components are correctly assembled, little or no Gold is required. If not....there are always fixes available if one does not forge ahead before asking why something looks "other than" Gray.With RS-MaxxMudd mixes, the Gray came from the paints base as much as from the Silver's tendency toward Gray. Silver tends to push Blue. So Gold was always a "in your back pocket if needed" thingee with a mix like RS-MaxxMudd.
also, how much paint would be needed to cover a ~100"er (probably mostly light/dusters, as its my first go)? I would like to 'reserve' an amount for the main application, and then i can use some extra for the tests to see what level of NG i might want to add to the LL - make sense?
Make the prescribed mix and you'll have an excess of about 30-40%
thanks - learning a lot here! the more you explain, the more questions i have
ya thin.....
S'why wer hear.
