AVS › AVS Forum › Audio › Speakers › Polk Audio 265RT for center channel?
post #1 of 2
Planning to see whether i can use Polk Audio 265 RT as center channel speakers. Has anyone used this for center channel and willing to hear feedback and comments on thsi model as center channel.
post #2 of 2
I was told you could run 3 265rt's together as a left, right, and use one as a center channel. And that it would be the optimal setting as they are all the same type of speakers- 3-way up front.
This is what I plan on doing as my theater room has a stud in the dead center that I'll have to cut regardless so I'm not worried its 20" across. The question I have though is same as yours. The more research I do I'm wondering if I'm better off going with 255c-RT instead?
Will some of the real audiophiles please answer this for us??
  Back to Forum: Speakers
