Electrohome 8000 lost focus, then lost picture.
while watching some videos, the projector would suddenly cut image, then come back from blurry and dim to sharp and bright. then one last time it did that same trick, and from then on has had no image at all. I am getting nothing that looks like an error light from the system. have power to the fans, can turn the unit on and off, and when on, I get the full complement of fans.
Am I likely looking at a HV PS? or another board somewhere?
with "reasonable" digitals well under 1K.... this may be my final push
Josh
Josh
6 screws and it slides out . A newer 8500 HVPS will also give you 200 more Lumens
