I'm getting a new TV for my master bedroom and expecting the internal sound to suck (it does with almost all the current flat screens). I don't want a full AVR and surround setup in the room so I plan to get a sound bar. I also don't want using it (turning it on/off, changing input sources, changing volume) to be a separate action or hassle or my wife will never use it (and I already can't get her to use our Harmony One downstairs so that's not an option).
What has me uncertain is it sounds like I can expect my TV not to pass anything better than 2.1 from the digital audio out with HDMI sources (which they all will be) if I go from the devices to the TV and then to the sound bar. On the other hand, I didn't want a fancy sound bar that was expensive or required a separate box (like the Yamaha 400) but on the other hand the inexpensive ones seem to lack HDMI pass-through. For example, I would be perfectly happy with the capacity of the Yamaha 101, but worry it won't work with my setup because the probable TV (Panasonic ST30) definitely does not pass 5.1 out for HDMI sources in.
Advice? And some specific questions:
1) Is it a given that the current model sound bars on the market with HDMI pass-through can handle passing through 3D video?
2) Do the sound bars with HDMI pass-through HDMI-CEC and not interfere with ARC-compatible devices?
3) Is there any solution for using a sound bar with HDMI pass-through with an ST30 using HDMI inputs that doesn't cut the signal to 2.1?
You are correct in that
