So, every since around driver release 290 or so, I began to notice something odd happening. Some games of mine wouldn't work anymore at 1080p. At first I thought it was a fluke, but then it just got worse with each new driver release.
My monitor is a now-many-years-old Westinghouse 1080p 16:9 monitor, 37". No tuner at all. Its just a big monitor with speakers. And for years it has worked flawlessly.
But around 290xxx from Nvidia, when I'd go to fire up certain games, instead of 1080p...I'd get.....diagonal lines of gibberish! Ok, just imagine the old days of trying to tune in a TV station, you'd see like just diagonal lines of static and pixels and so forth until the picture came into view (yes I'm talking the old old days of rabbit ears, kids)......that is sorta what I am looking at. Its as though the card is sending my monitor a signal that is out of sync or something.
SO I posted over on Nvidias web forums "Guys what gives, with each driver release the situation gets worse, 1080p no longer works!"......but nobody viewed and nobody responded.
So.....now I am effectively STUCK at driver release 285, the last release before things started going screwy. It doesn't have anything to do with overclocks on my card or running MSI Afterburner or anything like that, games simply start up but don't render correctly...as though the monitor and the card are saying "Ok, you're a 1080p monitor" and then the display just goes completely screwy.
I tried to do a screenshot...no luck since I had to reset the computer to get the graphics back to viewable. right now on my desktop everything is fine. But if I try to launch a game? SLAM....if I run the game at say 1600x1200?? No problem, works fine...just doesn't work at my monitors native resolution of 1080p anymore.
Has *ANYONE* Heard of this happening to other people before? I use a straight shot DVI to DVI1.....and if I try using the other DVI port on my video card it thinks my monitor is "monitor 2"....so I'm using the right DVI output port and the only DVI input on my display that will accept and display 1080p.
So i am sad and annoyed...I'm losing out on tons of performance....and I have YET to find a suitable 37" replacement for this monitor, is it just that the EDID in this display is so old that the newer nvidia drivers are doing something differently, causing it to screw up? I don't know but, I'm really kind of pissed.
I should note: That the "effect" seems to be associated with trying to send my monitor a signal at 59hz. When I add a custom resolution of 1920x1080 at 59hz the screen goes screwy, just like it does on games. When I click on nvidia properties it says its driving my monitor at 1080p, 60hz. however when I click on Windows 7 "Change Resolution" it says my monitor is displaying at 59hz. I can check 60hz and click APPLY but as soon as I go back to the screen again, it says its running at 59Hz. Ugh.......I have this sinking feeling that modern drivers are just doing something differently that causes these old displays to go wacky
UPDATE: its my monitor......plugged another monitor in and it runs fine at 1080p with all the same cables, etc.
I guess I'm going to have to do the EDID hack on my Westinghouse and create a custom entry in the registry and see if that gets me back into business...if not....i have no idea what is going on..and maybe its time to retire the old bastard.
PS: using a 25" Monitor IS A PAINFUL EXPERIENCE
I couldn't live with less than 32"........
