I know many consider these speakers to be "you can't go wrong with either" type choices. I also know similar threads are posted, which I've read. I've heard both and it is a difficult decision, indeed. In regard to the higher frequencies being more "mellow" or "smooth" on the CM8's, is choosing simply a matter of preference or are the Paradigm's actually revealing more detail in the higher frequencies? Also, is the Studio series still made in Canada or is it now made in China like the B&W's?
I also read in the other similar posts that the CMCC2 is far superior to the CMCC in regard to the center channel. This will be for a 12' x 14' room and possibly in a few years for a 14' x 24' room. Aside from the CMCC2 costing twice as much, will it be too much for the 12' x 14' room? This system will be 50/50 theater/music.
My 3rd option is going with the Paradigm SE3's which are supposed to fall between the Monitor series and the Studio series. Has anyone heard the SE series in comparison to the Studio series and the CM series from B&W?
This will be a 5.1 system but I'm leaving the surround speakers and the sub out of the equation for the purposes of this discussion. Thanks in advance for your help and suggestions.
