Here's what I'm considering so far - any input would be much appreciated:
Turntable:
Rega RP1
Reasonable choice.
Preamp
Rega Fono Mini
Not so reasonable. Most stereo receivers have built in phono stages. This one might well be better, but it's not better enough to justify devoting almost 15% of your system budget to it. If the receiver you wind up choosing doesn't have one, $50 or so will buy you a decent basic model.
Receiver
??? (really not sure what to look for here, want to stay under $200)
Look at the Onkyo TX-8255.
Speakers
Focal Chorus 705v
OK, but have you considered either towers or a 2.1 system?
A good general guideline is to put most of your budget into speakers. That's a little trickier when you've got a turntable in the mix, but the P1 and the Onkyo receiver I mentioned will run you a bit over $600, leaving you $700 for speakers.
