Originally Posted by Mike99
Mfusick,
I noticed the Apex case is 12.75 high/wide. Is that tight to work in? While I've upgraded every PC that I've had, this is a first time build for me & am concerned about the size.
I don't know how may cards will eventually end up in this HTPC, but will it handle a pair of tuner cards & a graphic card? When I did some of those PSU calculators they all came up with about 220W. If the Apex PSU has to be swapped does it use a standard size one?
Zon2020, et al,
Initially I thought about using an i3-2100 CPU. Then after reading more it seemed like the G620 would be just as good. I guess it's just a mental block against using a Celeron G530. Not to say that I can't be convinced to use a G530, but what, if any, performance hit would I take compared to the G620 if I want to use the PC for other things, such as authoring a video to DVD?
Mfusick,
Zon2020, et al,
Yes you can easily swap psu with any standard psu.
Also .. You probably do not need graphics card.
Next... G630 @ 2.7ghz for $61.99 is what I recommend. PM me if you need a link.
i3 is nice but the g630 will be enough. Good compromise between i3 and g530 and great value at 62$.
Last... There is plenty of room in that case. It is not my favorite but it's good and will work fine for a good price/value
