I am looking to build a whole house PVR setup and I need some guidance / suggestions.
My main goal is to have one central system that will record TV shows and be able to stream the recorded content to any of the TVs in my house. I am thinking of either Myth TV or Windows 7 Media Center with 3+ tuners with cable M-card (I have been looking at HD HomeRun Prime) since it looks to work with Linux or windows.
As a test system, I have MediaTomb installed on a linux system with a number of home movies installed in .m4v format. I have a popcorn hour A100 and an LG Blue-ray player that work great as extenders to play the contents at two TVs. I am just missing the capability to record and I need to buy a couple of additional extenders to connect to additional TVs.
The MediaTomb system is very old and I have no problem replacing with either an Off The Shelf or custom system. I just want to make sure the OTS system has the power that I need.
I have read that I should have at one core for each tuner so I will need a quad core.
HTPC -
OTS - need suggestions
DIY Build - need suggestions
tuners -
HD HomeRun PRIME
media extenders
Popcorn Hour
LG Blue-Ray player
any other suggestions?
I currently have TimeWarner DVR but it has only two tuners. I also have 3 ReplayTV systems that just stopped working. The TW DVR is fine except for storage space and only having two tuners.
Any suggestions
HTPC -
tuners -
HD HomeRun PRIME
media extenders
Popcorn Hour
LG Blue-Ray player
Any suggestions
